[petsc-dev] error with karlrupp/fix-cuda-streams
Mark Adams
mfadams at lbl.gov
Wed Sep 25 09:31:49 CDT 2019
No luck,
On Wed, Sep 25, 2019 at 10:01 AM Balay, Satish <balay at mcs.anl.gov> wrote:
> Mark,
> Can you try the fix in branch balay/fix-mpiexec-shell-escape and see if it
> works?
> Satish
> On Wed, 25 Sep 2019, Balay, Satish via petsc-dev wrote:
> > Mark,
> > Can you send configure.log from mark/fix-cuda-with-gamg-pintocpu branch?
> > Satish
> > On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> > > I double checked that a clean build of your (master) branch has this
> error
> > > by my branch (mark/fix-cuda-with-gamg-pintocpu), which may include
> stuff
> > > from Barry that is not yet in master, works.
> > > On Wed, Sep 25, 2019 at 5:26 AM Karl Rupp via petsc-dev <
> > > petsc-dev at mcs.anl.gov> wrote:
> > > > On 9/25/19 11:12 AM, Mark Adams via petsc-dev wrote:
> > > > > I am using karlrupp/fix-cuda-streams, merged with master, and I
> get this
> > > > > error:
> > > > > Could not execute "['jsrun -g\\ 1 -c\\ 1 -a\\ 1 --oversubscribe -n
> 1
> > > > > printenv']":
> > > > > Error, invalid argument: 1
> > > > > My branch mark/fix-cuda-with-gamg-pintocpu seems to work but I did
> edit
> > > > > the jsrun command but Karl's branch still fails. (SUMMIT was down
> today
> > > > > so there could have been updates).
> > > > > Any suggestions?
> > > > Looks very much like a systems issue to me.
> > > > Best regards,
> > > > Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/c2861489/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190925/c2861489/attachment-0001.obj>
