[petsc-dev] error with karlrupp/fix-cuda-streams
Balay, Satish
balay at mcs.anl.gov
Wed Sep 25 09:01:22 CDT 2019
Mark,
Can you try the fix in branch balay/fix-mpiexec-shell-escape and see if it works?
Satish
On Wed, 25 Sep 2019, Balay, Satish via petsc-dev wrote:
> Mark,
> Can you send configure.log from mark/fix-cuda-with-gamg-pintocpu branch?
> Satish
> On Wed, 25 Sep 2019, Mark Adams via petsc-dev wrote:
> > I double checked that a clean build of your (master) branch has this error
> > by my branch (mark/fix-cuda-with-gamg-pintocpu), which may include stuff
> > from Barry that is not yet in master, works.
> > On Wed, Sep 25, 2019 at 5:26 AM Karl Rupp via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> > > On 9/25/19 11:12 AM, Mark Adams via petsc-dev wrote:
> > > > I am using karlrupp/fix-cuda-streams, merged with master, and I get this
> > > > error:
> > > > Could not execute "['jsrun -g\\ 1 -c\\ 1 -a\\ 1 --oversubscribe -n 1
> > > > printenv']":
> > > > Error, invalid argument: 1
> > > > My branch mark/fix-cuda-with-gamg-pintocpu seems to work but I did edit
> > > > the jsrun command but Karl's branch still fails. (SUMMIT was down today
> > > > so there could have been updates).
> > > > Any suggestions?
> > > Looks very much like a systems issue to me.
> > > Best regards,
> > > Karli
