[petsc-dev] MatMult on Summit
    Mills, Richard Tran
    rtmills at anl.gov
    Tue Sep 24 00:46:37 CDT 2019
Karl, that would be fantastic. Much obliged!
--Richard
On 9/23/19 8:09 PM, Karl Rupp wrote:
`git grep cudaStreamCreate` reports that vectors, matrices and scatters create their own streams. This will almost inevitably create races (there is no synchronization mechanism implemented), unless one calls WaitForGPU() after each operation. Some of the non-deterministic tests can likely be explained by this.
I'll clean this up in the next few hours if there are no objections.
Best regards,
Karli
On 9/24/19 1:05 AM, Mills, Richard Tran via petsc-dev wrote:
I'm no CUDA expert (not yet, anyway), but, from what I've read, the default stream (stream 0) is (mostly) synchronous to host and device, so WaitForGPU() is not needed in that case. I don't know if there is any performance penalty in explicitly calling it in that case, anyway.
In any case, it looks like there are still some cases where potentially asynchronous CUDA library calls are being "timed" without a WaitForGPU() to ensure that the calls actually complete. I will make a pass through the aijcusparse and aijviennacl code looking for these.
--Richard
On 9/23/19 3:28 PM, Zhang, Junchao wrote:
It looks cusparsestruct->stream is always created (not NULL).  I don't know logic of the "if (!cusparsestruct->stream)".
--Junchao Zhang
On Mon, Sep 23, 2019 at 5:04 PM Mills, Richard Tran via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov> <mailto:petsc-dev at mcs.anl.gov><mailto:petsc-dev at mcs.anl.gov>> wrote:
    In MatMultAdd_SeqAIJCUSPARSE, before Junchao's changes, towards
    the end of the function it had
      if (!yy) { /* MatMult */
        if (!cusparsestruct->stream) {
          ierr = WaitForGPU();CHKERRCUDA(ierr);
    I assume we don't need the logic to do this only in the MatMult()
    with no add case and should just do this all the time, for the
    purposes of timing if no other reason. Is there some reason to NOT
    do this because of worries the about effects that these
    WaitForGPU() invocations might have on performance?
    I notice other problems in aijcusparse.cu <http://aijcusparse.cu><http://aijcusparse.cu>,
    now that I look closer. In MatMultTransposeAdd_SeqAIJCUSPARSE(), I
    see that we have GPU timing calls around the cusparse_csr_spmv()
    (but no WaitForGPU() inside the timed region). I believe this is
    another area in which we get a meaningless timing. It looks like
    we need a WaitForGPU() there, and then maybe inside the timed
    region handling the scatter. (I don't know if this stuff happens
    asynchronously or not.) But do we potentially want two
    WaitForGPU() calls in one function, just to help with getting
    timings? I don't have a good idea of how much overhead this adds.
    --Richard
    On 9/21/19 12:03 PM, Zhang, Junchao via petsc-dev wrote:
    I made the following changes:
    1) In MatMultAdd_SeqAIJCUSPARSE, use this code sequence at the end
      ierr = PetscLogGpuTimeEnd();CHKERRQ(ierr);
      ierr = PetscLogGpuFlops(2.0*a->nz);CHKERRQ(ierr);
      PetscFunctionReturn(0);
    2) In MatMult_MPIAIJCUSPARSE, use the following code sequence.
    The old code swapped the first two lines. Since with
    -log_view, MatMultAdd_SeqAIJCUSPARSE is blocking, I changed the
    order to have better overlap.
      ierr =
    VecScatterBegin(a->Mvctx,xx,a->lvec,INSERT_VALUES,SCATTER_FORWARD);CHKERRQ(ierr);
      ierr = (*a->A->ops->mult)(a->A,xx,yy);CHKERRQ(ierr);
      ierr =
    VecScatterEnd(a->Mvctx,xx,a->lvec,INSERT_VALUES,SCATTER_FORWARD);CHKERRQ(ierr);
      ierr = (*a->B->ops->multadd)(a->B,a->lvec,yy,yy);CHKERRQ(ierr);
    3) Log time directly in the test code so we can also know
    execution time without -log_view (hence cuda synchronization). I
    manually calculated the Total Mflop/s for these cases for easy
    comparison.
    <<Note the CPU versions are copied from yesterday's results>>
    Event                Count      Time (sec)     Flop                                 --- Global ---  --- Stage ----  Total   GPU    -
    CpuToGpu -   - GpuToCpu - GPU
                       Max Ratio  Max     Ratio   Max  Ratio  Mess      AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s
    Count   Size   Count   Size  %F
    6 MPI ranks,
    MatMult              100 1.0 1.1895e+01 1.0 9.63e+09 1.1 2.8e+03
    2.2e+05 0.0e+00 24 99 97 18  0 100100100100  0  4743       0         0 0.00e+00    0 0.00e+00  0
    VecScatterBegin      100 1.0 4.9145e-02 3.0 0.00e+00 0.0 2.8e+03
    2.2e+05 0.0e+00  0  0 97 18  0   0  0100100  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecScatterEnd        100 1.0 2.9441e+00 133 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  3  0  0  0  0  13  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    24 MPI ranks
    MatMult              100 1.0 3.1431e+00 1.0 2.63e+09 1.2 1.9e+04
    5.9e+04 0.0e+00  8 99 97 25  0 100100100100  0 17948       0         0 0.00e+00    0 0.00e+00  0
    VecScatterBegin      100 1.0 2.0583e-02 2.3 0.00e+00 0.0 1.9e+04
    5.9e+04 0.0e+00  0  0 97 25  0   0  0100100  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecScatterEnd        100 1.0 1.0639e+0050.0 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  2  0  0  0  0  19  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    42 MPI ranks
    MatMult              100 1.0 2.0519e+00 1.0 1.52e+09 1.3 3.5e+04
    4.1e+04 0.0e+00 23 99 97 30  0 100100100100  0 27493       0         0 0.00e+00    0 0.00e+00  0
    VecScatterBegin      100 1.0 2.0971e-02 3.4 0.00e+00 0.0 3.5e+04
    4.1e+04 0.0e+00  0  0 97 30  0   1  0100100  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecScatterEnd        100 1.0 8.5184e-0162.0 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  6  0  0  0  0  24  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    6 MPI ranks + 6 GPUs + regular SF + log_view
    MatMult              100 1.0 1.6863e-01 1.0 9.66e+09 1.1 2.8e+03
    2.2e+05 0.0e+00  0 99 97 18  0 100100100100  0 335743   629278     100 1.02e+02  100 2.69e+02 100
    VecScatterBegin      100 1.0 5.0157e-02 1.6 0.00e+00 0.0 2.8e+03
    2.2e+05 0.0e+00  0  0 97 18  0  24  0100100  0     0       0         0 0.00e+00  100 2.69e+02  0
    VecScatterEnd        100 1.0 4.9155e-02 2.5 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0  20  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecCUDACopyTo        100 1.0 9.5078e-03 2.0 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0   4  0  0  0  0     0       0       100 1.02e+02    0 0.00e+00  0
    VecCopyFromSome      100 1.0 2.8485e-02 1.4 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0  14  0  0  0  0     0       0         0 0.00e+00  100 2.69e+02  0
    6 MPI ranks + 6 GPUs + regular SF  + No log_view
    MatMult:             100 1.0 1.4180e-01        399268
    6 MPI ranks + 6 GPUs + CUDA-aware SF + log_view
    MatMult              100 1.0 1.1053e-01 1.0 9.66e+09 1.1 2.8e+03
    2.2e+05 0.0e+00  1 99 97 18  0 100100100100  0 512224   642075       0 0.00e+00    0 0.00e+00 100
    VecScatterBegin      100 1.0 8.3418e-03 1.5 0.00e+00 0.0 2.8e+03
    2.2e+05 0.0e+00  0  0 97 18  0   6  0100100  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecScatterEnd        100 1.0 2.2619e-02 1.6 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0  16  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    6 MPI ranks + 6 GPUs + CUDA-aware SF + No log_view
    MatMult:             100 1.0 9.8344e-02        575717
    24 MPI ranks + 6 GPUs + regular SF + log_view
    MatMult              100 1.0 1.1572e-01 1.0 2.63e+09 1.2 1.9e+04
    5.9e+04 0.0e+00  0 99 97 25  0 100100100100  0 489223   708601     100 4.61e+01  100 6.72e+01 100
    VecScatterBegin      100 1.0 2.0641e-02 2.0 0.00e+00 0.0 1.9e+04
    5.9e+04 0.0e+00  0  0 97 25  0  13  0100100  0     0       0         0 0.00e+00  100 6.72e+01  0
    VecScatterEnd        100 1.0 6.8114e-02 5.6 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0  38  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecCUDACopyTo        100 1.0 6.6646e-03 2.5 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0   3  0  0  0  0     0       0       100 4.61e+01    0 0.00e+00  0
    VecCopyFromSome      100 1.0 1.0546e-02 1.7 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  0  0  0  0  0   7  0  0  0  0     0       0         0 0.00e+00  100 6.72e+01  0
    24 MPI ranks + 6 GPUs + regular SF + No log_view
    MatMult:             100 1.0 9.8254e-02        576201
    24 MPI ranks + 6 GPUs + CUDA-aware SF + log_view
    MatMult              100 1.0 1.1602e-01 1.0 2.63e+09 1.2 1.9e+04
    5.9e+04 0.0e+00  1 99 97 25  0 100100100100  0 487956   707524       0 0.00e+00    0 0.00e+00 100
    VecScatterBegin      100 1.0 2.7088e-02 7.0 0.00e+00 0.0 1.9e+04
    5.9e+04 0.0e+00  0  0 97 25  0   8  0100100  0     0       0         0 0.00e+00    0 0.00e+00  0
    VecScatterEnd        100 1.0 8.4262e-02 3.0 0.00e+00 0.0 0.0e+00
    0.0e+00 0.0e+00  1  0  0  0  0  52  0  0  0  0     0       0         0 0.00e+00    0 0.00e+00  0
    24 MPI ranks + 6 GPUs + CUDA-aware SF + No log_view
    MatMult:             100 1.0 1.0397e-01        544510
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190924/9ba7ce82/attachment-0001.html>
