[petsc-dev] MatMult on Summit
Zhang, Junchao jczhang at mcs.anl.gov
Mon Sep 23 12:58:31 CDT 2019
The figure did not clearly say all cores share L3.  Instead, we should look at p.16 of https://www.redbooks.ibm.com/redpapers/pdfs/redp5472.pdf
"The POWER9 chip contains two memory controllers, PCIe Gen4 I/O controllers, and an interconnection system that connects all components within the chip at 7 TBps. Each core has 256 KB of L2 cache, and all cores share 120 MB of L3 embedded DRAM (eDRAM)."
--Junchao Zhang
On Mon, Sep 23, 2019 at 11:58 AM Mills, Richard Tran via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
L3 and L2 are shared between cores, actually. See the attached 'lstopo' PDF output from a Summit compute node to see an illustration of the node layout.
--Richard
On 9/23/19 9:01 AM, Zhang, Junchao via petsc-dev wrote:
I also did OpenMP stream test and then I found mismatch between OpenMPI and MPI.  That reminded me a subtle issue on summit: pair of cores share L2 cache.  One has to place MPI ranks to different pairs to get best bandwidth. See different bindings
https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n2c21g3r12d1b21l0= and https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n2c21g3r12d1b22l0=. Note each node has 21 cores. I assume that means 11 pairs. The new results are below. They match with we what I got from OpenMPI. The bandwidth is almost doubled from 1 to 2 cores per socket. IBM document also says each socket has two memory controllers. I could not find the core-memory controller affinity info. I tried different bindings but did not find huge difference.
#Ranks  Rate (MB/s)    Ratio over 2 ranks
1         29229.8       -
2         59091.0      1.0
4        112260.7      1.9
6        159852.8      2.7
8        194351.7      3.3
10       215841.0      3.7
12       232316.6      3.9
14       244615.7      4.1
16       254450.8      4.3
18       262185.7      4.4
20       267181.0      4.5
22       270290.4      4.6
24       221944.9      3.8
26       238302.8      4.0
--Junchao Zhang
On Sun, Sep 22, 2019 at 6:04 PM Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
  Junchao,
     For completeness could you please run with a single core? But leave the ratio as you have with over 2 ranks since that is the correct model.
   Thanks
     Barry
> On Sep 22, 2019, at 11:14 AM, Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
> I did stream test on Summit. I used the MPI version from petsc, but largely increased the array size N since one socket of Summit has 120MB L3 cache. I used MPI version since it was easy for me to distribute ranks evenly to the two sockets.
> The result matches with data released by OLCF (see attached figure) and data given by Jed. We can see the bandwidth saturates around 24 ranks.
> 2          59012.2834        1.00
> 4          70959.1475        1.20
> 6         106639.9837        1.81
> 8         138638.6929        2.35
> 10        171125.0873        2.90
> 12        196162.5197        3.32
> 14        215272.7810        3.65
> 16        229562.4040        3.89
> 18        242587.4913        4.11
> 20        251057.1731        4.25
> 22        258569.7794        4.38
> 24        265443.2924        4.50
> 26        266562.7872        4.52
> 28        267043.6367        4.53
> 30        266833.7212        4.52
> 32        267183.8474        4.53
> On Sat, Sep 21, 2019 at 11:24 PM Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
>   Junchao could try the PETSc (and non-PETSc) streams tests on the machine.
>   There are a few differences, compiler, the reported results are with OpenMP, different number of cores but yes the performance is a bit low. For DOE that is great, makes GPUs look better :-)
> > On Sep 21, 2019, at 11:11 PM, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
> > For an AIJ matrix with 32-bit integers, this is 1 flops/6 bytes, or 165
> > GB/s for the node for the best case (42 ranks).
> > My understanding is that these systems have 8 channels of DDR4-2666 per
> > socket, which is ~340 GB/s of theoretical bandwidth on a 2-socket
> > system, and 270 GB/s STREAM Triad according to this post
> >  https://openpowerblog.wordpress.com/2018/07/19/epyc-skylake-vs-power9-stream-memory-bandwidth-comparison-via-zaius-barreleye-g2/
> > Is this 60% of Triad the best we can get for SpMV?
> > "Zhang, Junchao via petsc-dev" <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> writes:
> >> 42 cores have better performance.
> >> 36 MPI ranks
> >> MatMult              100 1.0 2.2435e+00 1.0 1.75e+09 1.3 2.9e+04 4.5e+04 0.0e+00  6 99 97 28  0 100100100100  0 25145       0      0 0.00e+00    0 0.00e+00  0
> >> VecScatterBegin      100 1.0 2.1869e-02 3.3 0.00e+00 0.0 2.9e+04 4.5e+04 0.0e+00  0  0 97 28  0   1  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
> >> VecScatterEnd        100 1.0 7.9205e-0152.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  22  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >> --Junchao Zhang
> >> On Sat, Sep 21, 2019 at 9:41 PM Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov><mailto:bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>> wrote:
> >>  Junchao,
> >>    Mark has a good point; could you also try for completeness the CPU with 36 cores and see if it is any better than the 42 core case?
> >>  Barry
> >>  So extrapolating about 20 nodes of the CPUs is equivalent to 1 node of the GPUs for the multiply for this problem size.
> >>> On Sep 21, 2019, at 6:40 PM, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov><mailto:mfadams at lbl.gov<mailto:mfadams at lbl.gov>>> wrote:
> >>> I came up with 36 cores/node for CPU GAMG runs. The memory bus is pretty saturated at that point.
> >>> On Sat, Sep 21, 2019 at 1:44 AM Zhang, Junchao via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov><mailto:petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>>> wrote:
> >>> Here are CPU version results on one node with 24 cores, 42 cores. Click the links for core layout.
> >>> 24 MPI ranks, https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n6c4g1r14d1b21l0=
> >>> MatMult              100 1.0 3.1431e+00 1.0 2.63e+09 1.2 1.9e+04 5.9e+04 0.0e+00  8 99 97 25  0 100100100100  0 17948       0      0 0.00e+00    0 0.00e+00  0
> >>> VecScatterBegin      100 1.0 2.0583e-02 2.3 0.00e+00 0.0 1.9e+04 5.9e+04 0.0e+00  0  0 97 25  0   0  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>> VecScatterEnd        100 1.0 1.0639e+0050.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0  19  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>> 42 MPI ranks, https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n6c7g1r17d1b21l0=
> >>> MatMult              100 1.0 2.0519e+00 1.0 1.52e+09 1.3 3.5e+04 4.1e+04 0.0e+00 23 99 97 30  0 100100100100  0 27493       0      0 0.00e+00    0 0.00e+00  0
> >>> VecScatterBegin      100 1.0 2.0971e-02 3.4 0.00e+00 0.0 3.5e+04 4.1e+04 0.0e+00  0  0 97 30  0   1  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>> VecScatterEnd        100 1.0 8.5184e-0162.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0  24  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>> --Junchao Zhang
> >>> On Fri, Sep 20, 2019 at 11:48 PM Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov><mailto:bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>> wrote:
> >>>  Junchao,
> >>>   Very interesting. For completeness please run also 24 and 42 CPUs without the GPUs. Note that the default layout for CPU cores is not good. You will want 3 cores on each socket then 12 on each.
> >>>  Thanks
> >>>   Barry
> >>>  Since Tim is one of our reviewers next week this is a very good test matrix :-)
> >>>> On Sep 20, 2019, at 11:39 PM, Zhang, Junchao via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov><mailto:petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>>> wrote:
> >>>> Click the links to visualize it.
> >>>> 6 ranks
> >>>> https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n6c1g1r11d1b21l0=
> >>>> jsrun -n 6 -a 1 -c 1 -g 1 -r 6 --latency_priority GPU-GPU --launch_distribution packed --bind packed:1 js_task_info ./ex900 -f HV15R.aij -mat_type aijcusparse -vec_type cuda -n 100 -log_view
> >>>> 24 ranks
> >>>> jsrun -n 6 -a 4 -c 4 -g 1 -r 6 --latency_priority GPU-GPU --launch_distribution packed --bind packed:1 js_task_info ./ex900 -f HV15R.aij -mat_type aijcusparse -vec_type cuda -n 100 -log_view
> >>>> --Junchao Zhang
> >>>> On Fri, Sep 20, 2019 at 11:34 PM Mills, Richard Tran via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov><mailto:petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>>> wrote:
> >>>> Junchao,
> >>>> Can you share your 'jsrun' command so that we can see how you are mapping things to resource sets?
> >>>> --Richard
> >>>> On 9/20/19 11:22 PM, Zhang, Junchao via petsc-dev wrote:
> >>>>> I downloaded a sparse matrix (HV15R) from Florida Sparse Matrix Collection. Its size is about 2M x 2M. Then I ran the same MatMult 100 times on one node of Summit with -mat_type aijcusparse -vec_type cuda. I found MatMult was almost dominated by VecScatter in this simple test. Using 6 MPI ranks + 6 GPUs,  I found CUDA aware SF could improve performance. But if I enabled Multi-Process Service on Summit and used 24 ranks + 6 GPUs, I found CUDA aware SF hurt performance. I don't know why and have to profile it. I will also collect  data with multiple nodes. Are the matrix and tests proper?
> >>>>> Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   - GpuToCpu - GPU
> >>>>>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size   Count   Size  %F
> >>>>> 6 MPI ranks (CPU version)
> >>>>> MatMult              100 1.0 1.1895e+01 1.0 9.63e+09 1.1 2.8e+03 2.2e+05 0.0e+00 24 99 97 18  0 100100100100  0  4743       0      0 0.00e+00    0 0.00e+00  0
> >>>>> VecScatterBegin      100 1.0 4.9145e-02 3.0 0.00e+00 0.0 2.8e+03 2.2e+05 0.0e+00  0  0 97 18  0   0  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> VecScatterEnd        100 1.0 2.9441e+00133  0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0  13  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> 6 MPI ranks + 6 GPUs + regular SF
> >>>>> MatMult              100 1.0 1.7800e-01 1.0 9.66e+09 1.1 2.8e+03 2.2e+05 0.0e+00  0 99 97 18  0 100100100100  0 318057   3084009 100 1.02e+02  100 2.69e+02 100
> >>>>> VecScatterBegin      100 1.0 1.2786e-01 1.3 0.00e+00 0.0 2.8e+03 2.2e+05 0.0e+00  0  0 97 18  0  64  0100100  0     0       0      0 0.00e+00  100 2.69e+02  0
> >>>>> VecScatterEnd        100 1.0 6.2196e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  22  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> VecCUDACopyTo        100 1.0 1.0850e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5  0  0  0  0     0       0    100 1.02e+02    0 0.00e+00  0
> >>>>> VecCopyFromSome      100 1.0 1.0263e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  54  0  0  0  0     0       0      0 0.00e+00  100 2.69e+02  0
> >>>>> 6 MPI ranks + 6 GPUs + CUDA-aware SF
> >>>>> MatMult              100 1.0 1.1112e-01 1.0 9.66e+09 1.1 2.8e+03 2.2e+05 0.0e+00  1 99 97 18  0 100100100100  0 509496   3133521   0 0.00e+00    0 0.00e+00 100
> >>>>> VecScatterBegin      100 1.0 7.9461e-02 1.1 0.00e+00 0.0 2.8e+03 2.2e+05 0.0e+00  1  0 97 18  0  70  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> VecScatterEnd        100 1.0 2.2805e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  17  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> 24 MPI ranks + 6 GPUs + regular SF
> >>>>> MatMult              100 1.0 1.1094e-01 1.0 2.63e+09 1.2 1.9e+04 5.9e+04 0.0e+00  1 99 97 25  0 100100100100  0 510337   951558  100 4.61e+01  100 6.72e+01 100
> >>>>> VecScatterBegin      100 1.0 4.8966e-02 1.8 0.00e+00 0.0 1.9e+04 5.9e+04 0.0e+00  0  0 97 25  0  34  0100100  0     0       0      0 0.00e+00  100 6.72e+01  0
> >>>>> VecScatterEnd        100 1.0 7.2969e-02 4.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  42  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> VecCUDACopyTo        100 1.0 4.4487e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3  0  0  0  0     0       0    100 4.61e+01    0 0.00e+00  0
> >>>>> VecCopyFromSome      100 1.0 4.3315e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  29  0  0  0  0     0       0      0 0.00e+00  100 6.72e+01  0
> >>>>> 24 MPI ranks + 6 GPUs + CUDA-aware SF
> >>>>> MatMult              100 1.0 1.4597e-01 1.2 2.63e+09 1.2 1.9e+04 5.9e+04 0.0e+00  1 99 97 25  0 100100100100  0 387864   973391    0 0.00e+00    0 0.00e+00 100
> >>>>> VecScatterBegin      100 1.0 6.4899e-02 2.9 0.00e+00 0.0 1.9e+04 5.9e+04 0.0e+00  1  0 97 25  0  35  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> VecScatterEnd        100 1.0 1.1179e-01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  48  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> >>>>> --Junchao Zhang
> <SummitNode.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190923/1b9060ba/attachment-0001.html>
