[petsc-dev] MatMult on Summit
Mark Adams mfadams at lbl.gov
Sun Sep 22 07:11:50 CDT 2019
Note, my scans on cores/node were done with multiple nodes, with some
"interpolation" to higher node counts. There does seem to be contention on
the NIC.
Here is scaling with 42 cores/node, with GPUs. You can compare with my
previous 24 core/node.
Note, I just did this run once (for fun), data is a little noisy, title is
wrong (7 processes/GPU), and the x-axis is using the old 24 c/n process
counts.
Just sharing.
On Sat, Sep 21, 2019 at 11:17 PM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> 42 cores have better performance.
> 36 MPI ranks
> MatMult              100 1.0 2.2435e+00 1.0 1.75e+09 1.3 2.9e+04 4.5e+04
> 0.0e+00  6 99 97 28  0 100100100100  0 25145       0      0 0.00e+00    0
> 0.00e+00  0
> VecScatterBegin      100 1.0 2.1869e-02 3.3 0.00e+00 0.0 2.9e+04 4.5e+04
> 0.0e+00  0  0 97 28  0   1  0100100  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> VecScatterEnd        100 1.0 7.9205e-0152.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0  22  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> --Junchao Zhang
> On Sat, Sep 21, 2019 at 9:41 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>   Junchao,
>>     Mark has a good point; could you also try for completeness the CPU
>> with 36 cores and see if it is any better than the 42 core case?
>>   Barry
>>   So extrapolating about 20 nodes of the CPUs is equivalent to 1 node of
>> the GPUs for the multiply for this problem size.
>> > On Sep 21, 2019, at 6:40 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > I came up with 36 cores/node for CPU GAMG runs. The memory bus is
>> pretty saturated at that point.
>> > On Sat, Sep 21, 2019 at 1:44 AM Zhang, Junchao via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> > Here are CPU version results on one node with 24 cores, 42 cores. Click
>> the links for core layout.
>> > 24 MPI ranks,
>> https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n6c4g1r14d1b21l0=
>> > MatMult              100 1.0 3.1431e+00 1.0 2.63e+09 1.2 1.9e+04
>> 5.9e+04 0.0e+00  8 99 97 25  0 100100100100  0 17948       0      0
>> 0.00e+00    0 0.00e+00  0
>> > VecScatterBegin      100 1.0 2.0583e-02 2.3 0.00e+00 0.0 1.9e+04
>> 5.9e+04 0.0e+00  0  0 97 25  0   0  0100100  0     0       0      0
>> > VecScatterEnd        100 1.0 1.0639e+0050.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  2  0  0  0  0  19  0  0  0  0     0       0      0
>> > 42 MPI ranks,
>> https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n6c7g1r17d1b21l0=
>> > MatMult              100 1.0 2.0519e+00 1.0 1.52e+09 1.3 3.5e+04
>> 4.1e+04 0.0e+00 23 99 97 30  0 100100100100  0 27493       0      0
>> > VecScatterBegin      100 1.0 2.0971e-02 3.4 0.00e+00 0.0 3.5e+04
>> 4.1e+04 0.0e+00  0  0 97 30  0   1  0100100  0     0       0      0
>> > VecScatterEnd        100 1.0 8.5184e-0162.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  6  0  0  0  0  24  0  0  0  0     0       0      0
>> > --Junchao Zhang
>> > On Fri, Sep 20, 2019 at 11:48 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> >   Junchao,
>> >    Very interesting. For completeness please run also 24 and 42 CPUs
>> without the GPUs. Note that the default layout for CPU cores is not good.
>> You will want 3 cores on each socket then 12 on each.
>> >   Thanks
>> >    Barry
>> >   Since Tim is one of our reviewers next week this is a very good test
>> matrix :-)
>> > > On Sep 20, 2019, at 11:39 PM, Zhang, Junchao via petsc-dev <
>> > > Click the links to visualize it.
>> > > 6 ranks
>> > > https://jsrunvisualizer.olcf.ornl.gov/?s4f1o01n6c1g1r11d1b21l0=
>> > > jsrun -n 6 -a 1 -c 1 -g 1 -r 6 --latency_priority GPU-GPU
>> --launch_distribution packed --bind packed:1 js_task_info ./ex900 -f
>> HV15R.aij -mat_type aijcusparse -vec_type cuda -n 100 -log_view
>> > > 24 ranks
>> > > jsrun -n 6 -a 4 -c 4 -g 1 -r 6 --latency_priority GPU-GPU
>> > > --Junchao Zhang
>> > > On Fri, Sep 20, 2019 at 11:34 PM Mills, Richard Tran via petsc-dev <
>> > > Junchao,
>> > > Can you share your 'jsrun' command so that we can see how you are
>> mapping things to resource sets?
>> > > --Richard
>> > > On 9/20/19 11:22 PM, Zhang, Junchao via petsc-dev wrote:
>> > >> I downloaded a sparse matrix (HV15R) from Florida Sparse Matrix
>> Collection. Its size is about 2M x 2M. Then I ran the same MatMult 100
>> times on one node of Summit with -mat_type aijcusparse -vec_type cuda. I
>> found MatMult was almost dominated by VecScatter in this simple test. Using
>> 6 MPI ranks + 6 GPUs,  I found CUDA aware SF could improve performance. But
>> if I enabled Multi-Process Service on Summit and used 24 ranks + 6 GPUs, I
>> found CUDA aware SF hurt performance. I don't know why and have to profile
>> it. I will also collect  data with multiple nodes. Are the matrix and tests
>> proper?
>> > >> Event                Count      Time (sec)     Flop
>>             --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   -
>> GpuToCpu - GPU
>> > >>                    Max Ratio  Max     Ratio   Max  Ratio  Mess
>>  AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count
>>  Size   Count   Size  %F
>> > >> 6 MPI ranks (CPU version)
>> > >> MatMult              100 1.0 1.1895e+01 1.0 9.63e+09 1.1 2.8e+03
>> 2.2e+05 0.0e+00 24 99 97 18  0 100100100100  0  4743       0      0
>> > >> VecScatterBegin      100 1.0 4.9145e-02 3.0 0.00e+00 0.0 2.8e+03
>> 2.2e+05 0.0e+00  0  0 97 18  0   0  0100100  0     0       0      0
>> > >> VecScatterEnd        100 1.0 2.9441e+00133  0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  3  0  0  0  0  13  0  0  0  0     0       0      0
>> > >> 6 MPI ranks + 6 GPUs + regular SF
>> > >> MatMult              100 1.0 1.7800e-01 1.0 9.66e+09 1.1 2.8e+03
>> 2.2e+05 0.0e+00  0 99 97 18  0 100100100100  0 318057   3084009 100
>> 1.02e+02  100 2.69e+02 100
>> > >> VecScatterBegin      100 1.0 1.2786e-01 1.3 0.00e+00 0.0 2.8e+03
>> 2.2e+05 0.0e+00  0  0 97 18  0  64  0100100  0     0       0      0
>> 0.00e+00  100 2.69e+02  0
>> > >> VecScatterEnd        100 1.0 6.2196e-02 3.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0  22  0  0  0  0     0       0      0
>> > >> VecCUDACopyTo        100 1.0 1.0850e-02 2.3 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   5  0  0  0  0     0       0    100
>> 1.02e+02    0 0.00e+00  0
>> > >> VecCopyFromSome      100 1.0 1.0263e-01 1.2 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0  54  0  0  0  0     0       0      0
>> > >> 6 MPI ranks + 6 GPUs + CUDA-aware SF
>> > >> MatMult              100 1.0 1.1112e-01 1.0 9.66e+09 1.1 2.8e+03
>> 2.2e+05 0.0e+00  1 99 97 18  0 100100100100  0 509496   3133521   0
>> 0.00e+00    0 0.00e+00 100
>> > >> VecScatterBegin      100 1.0 7.9461e-02 1.1 0.00e+00 0.0 2.8e+03
>> 2.2e+05 0.0e+00  1  0 97 18  0  70  0100100  0     0       0      0
>> > >> VecScatterEnd        100 1.0 2.2805e-02 1.5 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0  17  0  0  0  0     0       0      0
>> > >> 24 MPI ranks + 6 GPUs + regular SF
>> > >> MatMult              100 1.0 1.1094e-01 1.0 2.63e+09 1.2 1.9e+04
>> 5.9e+04 0.0e+00  1 99 97 25  0 100100100100  0 510337   951558  100
>> 4.61e+01  100 6.72e+01 100
>> > >> VecScatterBegin      100 1.0 4.8966e-02 1.8 0.00e+00 0.0 1.9e+04
>> 5.9e+04 0.0e+00  0  0 97 25  0  34  0100100  0     0       0      0
>> 0.00e+00  100 6.72e+01  0
>> > >> VecScatterEnd        100 1.0 7.2969e-02 4.9 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0  42  0  0  0  0     0       0      0
>> > >> VecCUDACopyTo        100 1.0 4.4487e-03 1.8 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   3  0  0  0  0     0       0    100
>> 4.61e+01    0 0.00e+00  0
>> > >> VecCopyFromSome      100 1.0 4.3315e-02 1.9 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0  29  0  0  0  0     0       0      0
>> > >> 24 MPI ranks + 6 GPUs + CUDA-aware SF
>> > >> MatMult              100 1.0 1.4597e-01 1.2 2.63e+09 1.2 1.9e+04
>> 5.9e+04 0.0e+00  1 99 97 25  0 100100100100  0 387864   973391    0
>> > >> VecScatterBegin      100 1.0 6.4899e-02 2.9 0.00e+00 0.0 1.9e+04
>> 5.9e+04 0.0e+00  1  0 97 25  0  35  0100100  0     0       0      0
>> > >> VecScatterEnd        100 1.0 1.1179e-01 4.1 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  1  0  0  0  0  48  0  0  0  0     0       0      0
>> > >> --Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190922/5b7c56e7/attachment-0001.html>
Name: Screen Shot 2019-09-22 at 7.47.59 AM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190922/5b7c56e7/attachment-0001.png>
