[petsc-dev] MatMult on Summit
Karl Rupp rupp at iue.tuwien.ac.at
Sat Sep 21 23:08:30 CDT 2019
Hi Junchao,
thanks, these numbers are interesting.
Do you have an easy way to evaluate the benefits of a CUDA-aware MPI vs.
a non-CUDA-aware MPI that still keeps the benefits of your
packing/unpacking routines?
I'd like to get a feeling of where the performance gains come from. Is
it due to the reduced PCI-Express transfer for the scatters (i.e.
packing/unpacking and transferring only the relevant entries) on each
rank, or is it some low-level optimization that makes the MPI-part of
the communication faster? Your current MR includes both; it would be
helpful to know whether we can extract similar benefits for other GPU
backends without having to require "CUDA-awareness" of MPI. If the
benefits are mostly due to the packing/unpacking, we could carry over
the benefits to other GPU backends (e.g. upcoming Intel GPUs) without
having to wait for an "Intel-GPU-aware MPI".
Best regards,
Karli
On 9/21/19 6:22 AM, Zhang, Junchao via petsc-dev wrote:
> I downloaded a sparse matrix (HV15R
> <https://sparse.tamu.edu/Fluorem/HV15R>) from Florida Sparse Matrix
> Collection. Its size is about 2M x 2M. Then I ran the same MatMult 100
> times on one node of Summit with -mat_type aijcusparse -vec_type cuda. I
> found MatMult was almost dominated by VecScatter in this simple test.
> Using 6 MPI ranks + 6 GPUs,  I found CUDA aware SF could improve
> performance. But if I enabled Multi-Process Service on Summit and used
> 24 ranks + 6 GPUs, I found CUDA aware SF hurt performance. I don't know
> why and have to profile it. I will also collect  data with multiple
> nodes. Are the matrix and tests proper?
> Event                Count      Time (sec)     Flop
>           --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -
> - GpuToCpu - GPU
>                     Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
>   Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size
> Count   Size  %F
> 6 MPI ranks (CPU version)
> MatMult              100 1.0 1.1895e+01 1.0 9.63e+09 1.1 2.8e+03 2.2e+05
> 0.0e+00 24 99 97 18  0 100100100100  0  4743       0      0 0.00e+00
>   0 0.00e+00  0
> VecScatterBegin      100 1.0 4.9145e-02 3.0 0.00e+00 0.0 2.8e+03 2.2e+05
> 0.0e+00  0  0 97 18  0   0  0100100  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> VecScatterEnd        100 1.0 2.9441e+00133  0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  3  0  0  0  0  13  0  0  0  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> 6 MPI ranks + 6 GPUs + regular SF
> MatMult              100 1.0 1.7800e-01 1.0 9.66e+09 1.1 2.8e+03 2.2e+05
> 0.0e+00  0 99 97 18  0 100100100100  0 318057   3084009 100 1.02e+02
>   100 2.69e+02 100
> VecScatterBegin      100 1.0 1.2786e-01 1.3 0.00e+00 0.0 2.8e+03 2.2e+05
> 0.0e+00  0  0 97 18  0  64  0100100  0     0       0      0 0.00e+00
>   100 2.69e+02  0
> VecScatterEnd        100 1.0 6.2196e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  22  0  0  0  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> VecCUDACopyTo        100 1.0 1.0850e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   5  0  0  0  0     0       0    100 1.02e+02
>   0 0.00e+00  0
> VecCopyFromSome      100 1.0 1.0263e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  54  0  0  0  0     0       0      0 0.00e+00
>   100 2.69e+02  0
> 6 MPI ranks + 6 GPUs + CUDA-aware SF
> MatMult              100 1.0 1.1112e-01 1.0 9.66e+09 1.1 2.8e+03 2.2e+05
> 0.0e+00  1 99 97 18  0 100100100100  0 509496   3133521   0 0.00e+00
>   0 0.00e+00 100
> VecScatterBegin      100 1.0 7.9461e-02 1.1 0.00e+00 0.0 2.8e+03 2.2e+05
> 0.0e+00  1  0 97 18  0  70  0100100  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> VecScatterEnd        100 1.0 2.2805e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  17  0  0  0  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> 24 MPI ranks + 6 GPUs + regular SF
> MatMult              100 1.0 1.1094e-01 1.0 2.63e+09 1.2 1.9e+04 5.9e+04
> 0.0e+00  1 99 97 25  0 100100100100  0 510337   951558  100 4.61e+01
>   100 6.72e+01 100
> VecScatterBegin      100 1.0 4.8966e-02 1.8 0.00e+00 0.0 1.9e+04 5.9e+04
> 0.0e+00  0  0 97 25  0  34  0100100  0     0       0      0 0.00e+00
>   100 6.72e+01  0
> VecScatterEnd        100 1.0 7.2969e-02 4.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0  42  0  0  0  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> VecCUDACopyTo        100 1.0 4.4487e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   3  0  0  0  0     0       0    100 4.61e+01
>   0 0.00e+00  0
> VecCopyFromSome      100 1.0 4.3315e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  29  0  0  0  0     0       0      0 0.00e+00
>   100 6.72e+01  0
> 24 MPI ranks + 6 GPUs + CUDA-aware SF
> MatMult              100 1.0 1.4597e-01 1.2 2.63e+09 1.2 1.9e+04 5.9e+04
> 0.0e+00  1 99 97 25  0 100100100100  0 387864   973391    0 0.00e+00
>   0 0.00e+00 100
> VecScatterBegin      100 1.0 6.4899e-02 2.9 0.00e+00 0.0 1.9e+04 5.9e+04
> 0.0e+00  1  0 97 25  0  35  0100100  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> VecScatterEnd        100 1.0 1.1179e-01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0  48  0  0  0  0     0       0      0 0.00e+00
>   0 0.00e+00  0
> --Junchao Zhang
