[petsc-dev] PetscCUDAInitialize
Zhang, Junchao
jczhang at mcs.anl.gov
Thu Sep 19 15:53:24 CDT 2019
On Thu, Sep 19, 2019 at 3:24 PM Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
> On Sep 19, 2019, at 2:50 PM, Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
> I saw your update. In PetscCUDAInitialize we have
> /* First get the device count */
> err = cudaGetDeviceCount(&devCount);
> /* next determine the rank and then set the device via a mod */
> ierr = MPI_Comm_rank(comm,&rank);CHKERRQ(ierr);
> device = rank % devCount;
> err = cudaSetDevice(device);
> If we rely on the first CUDA call to do initialization, how could CUDA know these MPI stuff.
It doesn't, so it does whatever it does (which may be dumb).
Are you proposing something?
No. My test failed in CI with -cuda_initialize 0 on frog but I could not reproduce it. I'm doing investigation.
Barry
> --Junchao Zhang
> On Wed, Sep 18, 2019 at 11:42 PM Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
> Fixed the docs. Thanks for pointing out the lack of clarity
> > On Sep 18, 2019, at 11:25 PM, Zhang, Junchao via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
> > Barry,
> > I saw you added these in init.c
> > + -cuda_initialize - do the initialization in PetscInitialize()
> > Notes:
> > Initializing cuBLAS takes about 1/2 second there it is done by default in PetscInitialize() before logging begins
> > But I did not get otherwise with -cuda_initialize 0, when will cuda be initialized?
> > --Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190919/3f8899de/attachment-0001.html>
