[petsc-dev] fieldsplit + composite + ksp
Matthew Knepley
knepley at gmail.com
Wed Sep 18 09:04:27 CDT 2019
On Wed, Sep 18, 2019 at 10:01 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> On 18 Sep 2019, at 3:48 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Sep 18, 2019 at 2:49 AM Pierre Jolivet via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> Hello,
>> I’m solving the following dummy system
>> http://jolivet.perso.enseeiht.fr/composite_ksp.tar.gz
>> [A, B];[C, D], with a PCFIELDSPLIT. For the PC of D, I’m using a
>> PCCOMPOSITE with two sub PCs. One of which is a PCKSP.
>> Could you please help me figure out what is wrong in the following piece
>> of code, that may be launched with the following arguments:
>> $ mpirun -n 1 ./a.out -ksp_type preonly -pc_type fieldsplit
>> -fieldsplit_1_pc_type composite -fieldsplit_1_sub_1_pc_type ksp
>> -fieldsplit_1_sub_1_ksp_ksp_type gmres -fieldsplit_1_sub_1_ksp_pc_type gamg
>> -fieldsplit_1_sub_1_ksp_ksp_converged_reason
>> -fieldsplit_1_sub_1_ksp_pc_gamg_sym_graph 1
>> -fieldsplit_1_sub_1_ksp_pc_gamg_square_graph 10
>> -fieldsplit_1_sub_1_ksp_ksp_rtol 1e-8
>> It solves the dummy system twice, with a varying block D.
> Its not the PC, its the matrix. Everything in the PC gets resetup just
> like you want.
> I did MatEqual(S2_1, S2_001, &equal) and equal was false.
> They are not supposed to be equal, so that’s a good thing.
> Or are you doing the comparison _after_ the MatCopy?
Yes.
> I’m not sure of what is your point, sorry.
I think they might not actually have identical nonzero structure.
Matt
> Thanks,
> Pierre
> Thanks,
> Matt
>> It should give you:
>> Linear fieldsplit_1_sub_1_ksp_ solve converged due to
>> CONVERGED_RTOL iterations 8
>> solve #0: 16098.3
>> Linear fieldsplit_1_sub_1_ksp_ solve did not converge due to
>> DIVERGED_PC_FAILED iterations 0
>> PC_FAILED due to SUBPC_ERROR
>> solve #1: inf
>> If I switch line 70 to #if 0, I get the expected output:
>> solve #0: 16098.3
>> solve #1: 325.448
>> I’m realizing that this has probably nothing to do with the outer
>> PCFIELDSPLIT, but this comes from a rather large FSI solver, so reproducing
>> this behavior in “only” 97 SLOC is good enough for your I hope.
>> Thanks in advance,
>> Pierre
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190918/79725490/attachment-0001.html>
