[petsc-dev] PETSC_HAVE_ZLIB gone with PR #1853
Václav Hapla vaclav.hapla at erdw.ethz.ch
Thu Sep 5 14:34:41 CDT 2019
Ok, I agree it would be more systematic to detect whether the file uses compression and whether hdf5 is built with zlib. I will look at it soonish. Right now I will raise an issue.
Barry, it's not such a big deal for me. It's just that viewer is now untested which is a bit risky with respect to potential regressions.
Vaclav
5. září 2019 18:16:59 SELČ, Jed Brown <jed at jedbrown.org> napsal:
>Can we query HDF5 to determine whether it supports zlib?  When shipping
>shared libraries, some people will use a different libhdf5, so it'd be
>better to determine this at run-time.
>"Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
>>    Vaclav,
>>      At the time of the PR Jed complained about all the configure
>information passed to PETSc source that was not used or relevant to
>PETSc.
>>      Hence I did a cleanup, part of the cleanup was packages not
>directly used by PETSc no longer had information generated about them,
>zlib was
>> one of them because I did a grep of HAVE_ZLIB in PETSc which would
>not detect the zlib in the requires.
>>       We can certainly bring it back ASAP.
>>       But I'd like to explore additional options, since the use of
>zlib in the requires: location is a bit of a hack that only works for
>those specific tests.
>> You say that HDF fails when trying to process compressed HDF5 if HDF5
>was built without zlib. Is there any other way to determine if the HDF5
>file is compressed with zlib? An HDF5 call specifically or that? Some
>indicate in the file? If so our viewers could use this to check the
>file and generate a very useful error message instead of having HDF5
>misbehave when called.
>>       When bringing it back I will make it more specific, for example
>HDF5_BUILT_WITH_ZLIB because just because zlib exists it doesn't mean
>HDF5 was built with it.
>>       Sorry for the inconvenience, we'll fix it better than ever
>>     Barry
>>> On Sep 5, 2019, at 8:52 AM, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
>wrote:
>>> Barry, you did a petscconf.h cleanup in BitBucket PR #1834 (merge
>commit 52556f0f).
>>> The problem is PETSC_HAVE_ZLIB is no longer set when ZLIB is
>installed.
>>> That effectively disables my tests with `requires: zlib` in
>>>  src/mat/examples/tutorials/ex10.c
>>>  src/ksp/ksp/examples/tutorials/ex27.c
>>> That condition is there because loading an HDF5 file which uses
>compression without zlib installed leads to HDF5 errors (very cryptic
>at least in some older HDF5 versions).
>>> Was the PETSC_HAVE_ZLIB removal intentional? Could it be brought
>back?
>>> Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190905/5fefe686/attachment.html>
