[petsc-dev] note on submiting gitlab pipelines
    Balay, Satish
    balay at mcs.anl.gov
    Thu Oct 31 08:47:57 CDT 2019
Just a reminder:
We've had regular changes to CI - [.gitlab-ci.yaml] - so its generally
a good idea to rebase branches to latest maint/master before starting
any new test pipeline.
One can always check if .gitlab-ci.yaml was updated with:
git fetch
git log my-branch..master .gitlab-ci.yaml
[even without an updated .gitlab-ci.yaml - a rebase generally helps
with better usage of package cache for the builds - thus reducing
rebuilds of external-packages]
Satish
On Wed, 23 Oct 2019, Balay, Satish via petsc-dev wrote:
> A note to all petsc developers @gitlab who start test pipelines on
> MRs:
> Please rebase the MR branch over latest master (or maint - if
> appropriate) before starting the test pipeline pipeline to use latest
> ci fixes.
> i.e make sure e73aa2c6ed is in your branch - when the test is done.
> Without this fix - you might see a success status even-though some
> have tests failed. [so the results would be useless].
> One way to check if your branch has this fix:
> git branch --contains e73aa2c6ed <branch-name>
> thanks,
> Satish
