[petsc-dev] AVX kernels, old gcc, still broken
Smith, Barry F. bsmith at mcs.anl.gov
Fri Oct 25 10:14:37 CDT 2019
https://gitlab.com/petsc/petsc/issues/434
> On Oct 25, 2019, at 9:16 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   This needs to be fixed properly with a configure test(s) and not with huge and inconsistent checks like this
> #if defined(PETSC_HAVE_IMMINTRIN_H) && defined(__AVX512F__) && defined(PETSC_USE_REAL_DOUBLE) && !defined(PETSC_USE_COMPLEX) && !defined(PETSC_USE_64BIT_INDICES)  or this
> #elif defined(PETSC_USE_AVX512_KERNELS) && defined(PETSC_HAVE_IMMINTRIN_H) && defined(__AVX512F__) && defined(PETSC_USE_REAL_DOUBLE) && !defined(PETSC_USE_COMPLEX) && !defined(PETSC_USE_64BIT_INDICES) && !defined(PETSC_SKIP_IMMINTRIN_H_CUDAWORKAROUND)
>   self.useAVX512Kernels = self.framework.argDB['with-avx512-kernels']
>    if self.useAVX512Kernels:
>      self.addDefine('USE_AVX512_KERNELS', 1)
>     Here you should check that the needed include files are available, that it is 32 bit integers, that defined(__AVX512F__) exists and that appropriate functions exist.
>    Maybe you need two configure checks if there are two different types of functionality you are trying to catch?
>    Continuing to hack away with gross #if def means this crud is unmaintainable and will always haunt you. Yes the incremental cost of doing a proper configure test is there but once that is done the maintenance costs (which have been haunting use for months) will be gone.
>  Barry
>> On Oct 25, 2019, at 2:49 AM, Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>> On Fri, 25 Oct 2019 at 01:40, Balay, Satish <balay at mcs.anl.gov> wrote:
>> I'm curious why this issue comes up for you. The code was unrelated to --with-avx512-kernels=0 option.
>> Its relying on __AVX512F__and PETSC_HAVE_IMMINTRIN_H flags. And
>> assumes immintrin.h has a definition for _mm512_reduce_add_pd()
>> Is the flag __AVX512F__ always set on your machine by gcc?
>> And does this change based on the hardware? I just tried this build
>> [same os/compiler] on "Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz" - and
>> can't reproduce the issue.
>> I do see _mm512_reduce_add_pd is missing from immintrin.h - but the
>> flag __AVX512F__ is not set for me.
>> Of course it is not set, you are just invoking the preprocessor. Try this way:
>> $ cat xyz.c
>> #if defined __AVX512F__
>> #error "avx512f flag set"
>> #endif
>> $ gcc -march=native -c xyz.c
>> xyz.c:2:2: error: #error "avx512f flag set"
>> I forgot to mention my XXXOPTFLAGS, full reconfigure script below.
>> Do we have some Ubuntu 16 builder using system GCC?
>> Maybe we should use `-march=native -O3 -g3` in one of these builders?
>> $ cat arch-gnu-opt/lib/petsc/conf/reconfigure-arch-gnu-opt.py
>> #!/usr/bin/python
>> if __name__ == '__main__':
>>  import sys
>>  import os
>>  sys.path.insert(0, os.path.abspath('config'))
>>  import configure
>>  configure_options = [
>>    '--COPTFLAGS=-march=native -mtune=native -O3',
>>    '--CXXOPTFLAGS=-march=native -mtune=native -O3',
>>    '--FOPTFLAGS=-march=native -mtune=native -O3',
>>    '--download-metis=1',
>>    '--download-p4est=1',
>>    '--download-parmetis=1',
>>    '--with-avx512-kernels=0',
>>    '--with-debugging=0',
>>    '--with-fortran-bindings=0',
>>    '--with-zlib=1',
>>    'CC=mpicc',
>>    'CXX=mpicxx',
>>    'FC=mpifort',
>>    'PETSC_ARCH=arch-gnu-opt',
>>  configure.petsc_configure(configure_options)
>> Lisandro Dalcin
>> Research Scientist
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
