[petsc-dev] AVX kernels, old gcc, still broken
Lisandro Dalcin
dalcinl at gmail.com
Fri Oct 25 02:49:32 CDT 2019
On Fri, 25 Oct 2019 at 01:40, Balay, Satish <balay at mcs.anl.gov> wrote:
> I'm curious why this issue comes up for you. The code was unrelated to
> --with-avx512-kernels=0 option.
> Its relying on __AVX512F__and PETSC_HAVE_IMMINTRIN_H flags. And
> assumes immintrin.h has a definition for _mm512_reduce_add_pd()
> Is the flag __AVX512F__ always set on your machine by gcc?
> And does this change based on the hardware? I just tried this build
> [same os/compiler] on "Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz" - and
> can't reproduce the issue.
> I do see _mm512_reduce_add_pd is missing from immintrin.h - but the
> flag __AVX512F__ is not set for me.
Of course it is not set, you are just invoking the preprocessor. Try this
way:
$ cat xyz.c
#if defined __AVX512F__
#error "avx512f flag set"
#endif
$ gcc -march=native -c xyz.c
xyz.c:2:2: error: #error "avx512f flag set"
I forgot to mention my XXXOPTFLAGS, full reconfigure script below.
Do we have some Ubuntu 16 builder using system GCC?
Maybe we should use `-march=native -O3 -g3` in one of these builders?
$ cat arch-gnu-opt/lib/petsc/conf/reconfigure-arch-gnu-opt.py
#!/usr/bin/python
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--COPTFLAGS=-march=native -mtune=native -O3',
'--CXXOPTFLAGS=-march=native -mtune=native -O3',
'--FOPTFLAGS=-march=native -mtune=native -O3',
'--download-metis=1',
'--download-p4est=1',
'--download-parmetis=1',
'--with-avx512-kernels=0',
'--with-debugging=0',
'--with-fortran-bindings=0',
'--with-zlib=1',
'CC=mpicc',
'CXX=mpicxx',
'FC=mpifort',
'PETSC_ARCH=arch-gnu-opt',
configure.petsc_configure(configure_options)
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191025/fd99d6cb/attachment.html>
