[petsc-dev] [Suggestion] Configure QOL Improvements
    Matthew Knepley
    knepley at gmail.com
    Wed Oct 23 13:35:50 CDT 2019
On Wed, Oct 23, 2019 at 2:27 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > On Wed, Oct 23, 2019 at 11:24 AM Faibussowitsch, Jacob via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> >> As I am largely unfamiliar with the internals of the configure process,
> >> this is potentially more of an involved change than I am imagining,
> given
> >> that many libraries likely have many small dependencies and hooks which
> >> have to be set throughout the configuration process, and so its possible
> >> not everything could be skipped.
> > We had this many years ago. It was removed because the benefits did not
> > outweigh the costs.
> I don't know if it's still the case, but it should be possible to run
> non-interactively (like apt-get -y).  My bigger complaint is that
> missing dependencies aren't resolved in the first couple seconds.
How do you know that you actually have something until you actually run the
tests? This is the classic
misconception of pkg-config, "I'll just believe the user", which generated
99% of user mail over the first
20 years of PETSc.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191023/dbd8758b/attachment.html>
