[petsc-dev] Wrong "failed tests" command
Scott Kruger kruger at txcorp.com
Mon Oct 21 13:55:46 CDT 2019
When we created the map of directory+test+variants to targets we did not
use enough delimiters to allow the inverse map to be determined so
creating the proper list of target names is an ill-posed problem.   The
globsearch was a way of trying to just catch more of them, but obviously
it still has a bug.  I'll look at it.
Scott
On 10/21/19 12:47 PM, Jed Brown wrote:
> Yeah, it's missing the numeric block size.  The following works
> /usr/bin/make -f gmakefile test globsearch='mat_tests-ex128_1 mat_tests-ex37_nsize-2_mat_type-mpibaij_mat_block_size-1'
> Also, globsearch can be replaced by search in this usage.
> "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
>>    May need more work on the tester infrastructure?
>>> On Oct 21, 2019, at 12:30 PM, Pierre Jolivet via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
>>> Hello,
>>> In this pipeline build log, https://gitlab.com/petsc/petsc/-/jobs/326525063, it shows that I can rerun failed tests using the following command:
>>> /usr/bin/make -f gmakefile test globsearch='mat_tests-ex128_1 mat_tests-ex37_nsize-2_mat_type-mpibaij_mat_block_size mat_tests-ex37_nsize-1_mat_type-mpibaij_mat_block_size mat_tests-ex128_2 mat_tests-ex37_nsize-2_mat_type-baij_mat_block_size mat_tests-ex37_nsize-1_mat_type-baij_mat_block_size mat_tests-ex30_4 mat_tests-ex37_nsize-2_mat_type-sbaij_mat_block_size mat_tests-ex18_* mat_tests-ex76_3 mat_tests-ex37_nsize-2_mat_type-mpisbaij_mat_block_size mat_tests-ex37_nsize-1_mat_type-sbaij_mat_block_size’
>>> If used, this command does not run any of the mat_test-ex37* tests.
>>> Thanks,
>>> Pierre
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
