[petsc-dev] BlockGetIndices and GetBlockIndices
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Oct 20 23:42:45 CDT 2019
  Could you provide a use case where you want to access/have a block size of a IS that is not an ISBlock?
> On Oct 16, 2019, at 2:50 AM, Pierre Jolivet via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Hello,
> I’m trying to understand what is the rationale for naming a function ISBlockGetIndices and another ISLocalToGlobalMappingGetBlockIndices (BlockGet vs. GetBlock).
> Also, it looks to me like the implementation of ISBlockGetIndices is somehow less versatile than ISLocalToGlobalMappingGetBlockIndices.
> Indeed, I may call ISLocalToGlobalMappingGetBlockIndices with an underlying non-block IS, while I can’t for ISBlockGetIndices, so a check must be performed by the user, e.g., https://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/is/examples/tutorials/ex3.c.html#line58 or this (IMHO) ugly code duplication https://www.mcs.anl.gov/petsc/petsc-dev/src/vec/is/utils/isltog.c.html#line322.
> Thoughts and/or comments? Would it make sense to add an ISGetBlockIndices/ISRestoreBlockIndices or would that be too confusing for the user?
> Thanks,
> Pierre
