[petsc-dev] Right-preconditioned GMRES
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Sun Oct 13 02:41:09 CDT 2019
Hello,
I’m struggling to understand the following weirdness with PCASM with exact subdomain solvers.
I’m dealing with a very simple Poisson problem with Dirichlet + Neumann BCs.
If I use PCBJACOBI + KSPPREONLY or 1 iteration of GMRES either preconditioned on the right or on the left, I get the expected result, cf. attached screenshot.
If I use PCASM + KSPPREONLY or 1 iteration of GMRES preconditioned on the left, I get the expected result as well.
However, with PCASM + 1 iteration of GMRES preconditioned on the right, I don’t get what I should (I believe).
Furthermore, this problem is specific to -pc_asm_type restrict,none (I get the expected result with basic,interpolate).
Any hint?
Pierre
$ -sub_pc_type lu -ksp_max_it 1 -ksp_type gmres -pc_type bjacobi -ksp_pc_side right -> bjacobi_OK
$ -sub_pc_type lu -ksp_max_it 1 -ksp_type gmres -pc_type asm -ksp_pc_side left -> asm_OK
$ -sub_pc_type lu -ksp_max_it 1 -ksp_type gmres -pc_type asm -ksp_pc_side right -> asm_KO
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191013/8a2b8d5c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191013/8a2b8d5c/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191013/8a2b8d5c/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191013/8a2b8d5c/attachment-0005.png>
