[petsc-dev] Best Way to Assign Cell Number to VTK Plot in DMPlex
Matthew Knepley
knepley at gmail.com
Fri Oct 4 09:42:33 CDT 2019
On Thu, Oct 3, 2019 at 11:42 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 1, 2019 at 11:57 AM Faibussowitsch, Jacob via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> Hello All,
>> I am plotting an output value from a vecview, and want to show in a
>> separate plot which cells correspond to which values in the vec. I plan to
>> do this by making a field on the cells whose value is the global number of
>> that cell. I have 2 issues with this:
>> 1. How do I guarantee that the ordering of the Vec I made corresponds to
>> the DMPlex cell ordering such that Vec(0) corresponds to Cells(0) etc. (I
>> make the Vec separately from the DM since using DMCreateLocalVector makes a
>> vector on the vertices)
>> 2. I am trying to use DMPlexVTKWriteAll to make my output, so I am adding
>> my field to the DMPlexVTK using PetscViewerVTKAddField, but I can’t seem to
>> get PetscViewerVTKWriteFunction to work properly, and the man pages don’t
>> link to an example. Here is my code for this section:
>> PetscErrorCode (*PetscViewerVTKWriteFunction) (PetscObject,
>> PetscViewer);
>> ierr = PetscViewerCreate(comm=PETSC_COMM_WORLD, &vtkviewer);CHKERRQ(ierr);
>> ierr = PetscViewerVTKOpen(comm=PETSC_COMM_WORLD, "mesh.vtk",
>> FILE_MODE_WRITE, &vtkviewer);CHKERRQ(ierr);
>> ierr = PetscViewerSetUp(vtkviewer);CHKERRQ(ierr);
>> PetscViewerVTKWriteFunction = (CellNum vtkviewer);
>> ierr = PetscViewerVTKAddField(vtkviewer, (PetscObject) dm,
>> PetscViewerVTKWriteFunction, PETSC_VTK_CELL_FIELD, PETSC_TRUE,
>> CellNum);CHKERRQ(ierr);
>> ierr = DMPlexVTKWriteAll((PetscObject) dm, vtkviewer);CHKERRQ(ierr);
>> Any help would be greatly appreciated!
> I think what you want is to make a Section over cells with 1 dof, fill it
> with the cell number (from a global numbering), and then view that Vec.
Here is me making a similar field containing the rank instead of the cell
number:
https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexCreateRankField.html
Note that Paraview already knows the cell number and can display it
Matt
> Matt
>> Best,
>> Jacob
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191004/c63f6614/attachment-0001.html>
