[petsc-dev] Why no SpGEMM support in AIJCUSPARSE and AIJVIENNACL?
    Mills, Richard Tran
    rtmills at anl.gov
    Thu Oct  3 14:04:24 CDT 2019
On 10/3/19 1:12 AM, Karl Rupp wrote:
Do you have any experience with nsparse?
https://github.com/EBD-CREST/nsparse
I've seen claims that it is much faster than cuSPARSE for sparse
matrix-matrix products.
I haven't tried nsparse, no.
But since the performance comes from a hardware feature (cache), I would be surprised if there is a big performance leap over ViennaCL. (There's certainly some potential for some tweaking of ViennaCL's kernels; but note that even ViennaCL is much faster than cuSPARSE's spGEMM on average).
With the libaxb-wrapper we can just add nsparse as an operations backend and then easily try it out and compare against the other packages. In the end it doesn't matter which package provides the best performance; we just want to leverage it :-)
I'd be happy to add support for this (though I suppose I should play with it first to verify that it is, in fact, worthwhile). Karl, is your branch with libaxb ready for people to start using it, or should we wait for you to do more with it? (Or, would you like any help with it?)
I'd like to try to add support for a few things like cuSPARSE SpGEMM before I go to the Summit hackathon, but I don't want to write a bunch of code that will be thrown away once your libaxb approach is in place.
--Richard
Best regards,
Karli
Karl Rupp via petsc-dev <petsc-dev at mcs.anl.gov><mailto:petsc-dev at mcs.anl.gov> writes:
Hi Richard,
CPU spGEMM is about twice as fast even on the GPU-friendly case of a
single rank: http://viennacl.sourceforge.net/viennacl-benchmarks-spmm.html
I agree that it would be good to have a GPU-MatMatMult for the sake of
experiments. Under these performance constraints it's not top priority,
though.
Best regards,
Karli
On 10/3/19 12:00 AM, Mills, Richard Tran via petsc-dev wrote:
Fellow PETSc developers,
I am wondering why the AIJCUSPARSE and AIJVIENNACL matrix types do not
support the sparse matrix-matrix multiplication (SpGEMM, or MatMatMult()
in PETSc parlance) routines provided by cuSPARSE and ViennaCL,
respectively. Is there a good reason that I shouldn't add those? My
guess is that support was not added because SpGEMM is hard to do well on
a GPU compared to many CPUs (it is hard to compete with, say, Intel Xeon
CPUs with their huge caches) and it has been the case that one would
generally be better off doing these operations on the CPU. Since the
trend at the big supercomputing centers seems to be to put more and more
of the computational power into GPUs, I'm thinking that I should add the
option to use the GPU library routines for SpGEMM, though. Is there some
good reason to *not* do this that I am not aware of? (Maybe the CPUs are
better for this even on a machine like Summit, but I think we're at the
point that we should at least be able to experimentally verify this.)
--Richard
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191003/e65f720a/attachment.html>
