[petsc-dev] Help to fix manual pages
Patrick Sanan
patrick.sanan at gmail.com
Wed Oct 2 09:31:24 CDT 2019
I think that there at least needs to be a dash at the end of each line
defining an option, or sowing gets confused.
Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> schrieb am Mi. 2.
Okt. 2019 um 16:15:
> In this one, the rendering of options database is broken,
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSADAPTDSP.html
> In the source code (look for TSAdaptCreate_DSP ) I wrote
> Options Database:
> + -ts_adapt_dsp_filter <name>
> . -ts_adapt_dsp_pid <kkI,kkP,kkD>
> . -ts_adapt_dsp_kbeta <b1,b2,b2>
> - -ts_adapt_dsp_alpha <a2,a3>
> What's the correct way to typeset that list?
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191002/3137fb44/attachment.html>
