[petsc-dev] Makefile with latest PETSc
    Tabrez Ali
    tabrezali at gmail.com
    Tue Oct  1 05:36:45 CDT 2019
Hello
I am trying to compile a simple Fortran program and it works fine with
PETSc 3.10 but fails with the latest version, e.g., see below:
$ make clean; make exe PETSC_DIR=/opt/petsc-3.10.5_clang_uni
flang -c -fPIC -Wall -Wno-unused-variable -g -O3
 -I/opt/petsc-3.10.5_clang_uni/include
-I/opt/petsc-3.10.5_clang_uni/arch-linux2-c-opt/include    -o m_foo.o
m_foo.F90
-I/opt/petsc-3.10.5_clang_uni/arch-linux2-c-opt/include    -o bar.o bar.F90
flang -fPIC -Wall -Wno-unused-variable -g -O3   -o exe m_foo.o bar.o
-Wl,-rpath,/opt/petsc-3.10.5_clang_uni/arch-linux2-c-opt/lib
-L/opt/petsc-3.10.5_clang_uni/arch-linux2-c-opt/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/8
-L/usr/lib/gcc/x86_64-linux-gnu/8 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -Wl,-rpath,/opt/flang/lib -L/opt/flang/lib
-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.4.243/linux/mpi/intel64/libfabric/lib
-L/opt/intel/compilers_and_libraries_2019.4.243/linux/mpi/intel64/libfabric/lib
-Wl,-rpath,/opt/intel/compilers_and_libraries_2019.4.243/linux/tbb/lib/intel64/gcc4.7
-L/opt/intel/compilers_and_libraries_2019.4.243/linux/tbb/lib/intel64/gcc4.7
-lpetsc -llapack -lblas -lm -lpthread -lflangmain -lstdc++ -ldl -lflang
-lflangrti -lpgmath -lompstub -lm -lrt -lpthread -lgcc_s -lstdc++ -ldl
$ make clean; make exe PETSC_DIR=/home/stali/petsc-dev
make: *** No rule to make target 'm_foo.o', needed by 'exe'.  Stop.
Any ideas as to what could be wrong? Here's the Makefile ...
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
OBJS = m_foo.o bar.o
exe: ${OBJS}
         ${FLINKER} -o exe ${OBJS} ${PETSC_LIB}
Thanks in advance.
Tabrez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191001/502eaf70/attachment.html>
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20191001/502eaf70/attachment.bin>
