[petsc-dev] Gitlab notifications and labels
    Scott Kruger
    kruger at txcorp.com
    Thu Nov 14 18:03:09 CST 2019
In a conversation with Barry, he mentioned that we hadn't
really discussed label subscription on this mailing list,
despite the fact that this is perhaps the more useful control
of notifications than what is in given in Settings.
Following up on this discussion, if folks go here:
   https://gitlab.com/petsc/petsc/-/labels
you can then subscribe to the labels that you want
notifications for.  This is potentially the best method
for subscribing to PETSc development notifications, and
better than just *Participate* level which I had advocated
for earlier.  I'll now advocate for *Participate* globally,
and label subscription locally.
Of course, this requires all folks who start an MR/Issue
to appropriately use labels.  But if you want a response,
you should expect to need this to get the response you want.
And of course, this requires accurate labels.  For example,
I notice that there is no label for folks developing
DM, even though that is, perhaps, the most active area of
development.  Do you require a new label?  (asks the
not-a-dm-dev).
Scott
P.S.  This means that I will stop using @person for GPU
discussions and just use the GPU label. Subscribe now GPU devs!
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
