[petsc-dev] SNESSetKSP and SNESDestroy
Stefano Zampini
stefano.zampini at gmail.com
Thu May 30 07:59:57 CDT 2019
I think snes reset should call ksp destroy. I don't see the case for which
this can lead to troubles
Il Gio 30 Mag 2019, 15:43 Matthew Knepley via petsc-dev <
petsc-dev at mcs.anl.gov> ha scritto:
> On Thu, May 30, 2019 at 6:08 AM Pierre Jolivet via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> Hello,
>> I’m doing a continuation loop with something like:
>> KSP ksp;
>> KSPSetUp(ksp);
>> while(cond) {
>> SNES snes;
>> SNESCreate(&snes);
>> SNESSetKSP(snes, &ksp);
>> SNESSolve(snes);
>> SNESDestroy(&snes);
>> For the first iteration, everything is OK.
>> After that, it looks like SNESDestroy is messing up with my outer-defined
>> KSP(*), i.e., for the code to work I need to comment out the SNESDestroy.
>> Is this the expected behavior? (if not, I’ll provide a MWE)
>> How to fix this properly, without having leaks by not destroying the
>> inner-defined SNESes?
>> Thanks in advance,
>> Pierre
>> (*) to the outer-defined KSP is attached a PCFIELDSPLIT, first SNESSolve,
>> everything OK:
>> PC Object: 1 MPI processes
>> type: fieldsplit
>> FieldSplit with MULTIPLICATIVE composition: total splits = 2
>> Second SNESSolve:
>> [0]PETSC ERROR: PCFieldSplitSetDefaults() Unhandled case, must have at
>> least two fields, not 1
> I believe SNESDestroy() calls SNESReset(), which calls KSPReset(), which
> is wiping out your information.
> This pattern is in a lot of places. Destroy calls Reset because it is
> natural to reuse the code which tears down
> the internal structures. Reset calls reset on subobjects because we also
> want to tear down their internal structures (usually).
> Reset wouldn't do what we want on resizing if we left subobjects unreset.
> However, this chain is causing subobjects to
> be wiped clean on Destroy, so that we cannot reuse subobjects.
> It would not even work if you change the Destroy to Reset in the
> continuation loop. However, I think you can hoist all
> the SNES setup outside the loop. If you are changing sizes, then the KSP
> needs to be wiped out anyway. If not, then
> you do not need to wipe out the SNES.
> Thanks,
> Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190530/81f728f1/attachment.html>
