[petsc-dev] PETSC_VIEWER_*_() vs PetscOptionsGetViewer()
    Matthew Knepley
    knepley at gmail.com
    Tue May 28 21:02:10 CDT 2019
On Tue, May 28, 2019 at 9:45 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   MatViewFromOptions(A,NULL,"-mat_view");
>   VecViewFromOptions(v,NULL,"-vec_view");
> $ PETSC_OPTIONS="" ./ex1000 -mat_view :testfile -vec_view :testfile::append
> $ more testfile
> Mat Object: 1 MPI processes
>   type: seqaij
> row 0: (0, 0.0718163)  (2, 0.720032)
> row 1: (0, 0.217676)  (1, 0.397778)
> row 2: (0, 0.354647)  (2, 0.984052)
> Vec Object: 1 MPI processes
>   type: seq
> 0.
> 0.
> 0.
> $ more testfile
>   type: seqaij
>   I'm not opposed to fixing up the current situation I just submit that we
> don't know how to fix up the current situation
Yes, I agree that you have to know what order things come in. I just
assumed you did. This is definitely a limitation.
    Matt
> > On May 28, 2019, at 8:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, May 28, 2019 at 5:46 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > > On May 28, 2019, at 4:40 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Tue, May 28, 2019 at 5:26 PM Smith, Barry F. via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > >   I have concerns.
> > >   Without the use of singletons
> > >    -mat_view binary -vec_view binary
> > >   will result in only the final object viewed being in the file
> binaryoutput? The idea behind the singletons is they provide continuity for
> the entire run.
> > >   Note that currently when also creating and destroying the viewers
> with the same name you only get the most recent stuff. In fact something
> like
> > >    -mat_view hdf5:myfile
> > >   is likely now buggy since it will only save the most recent matrix
> viewed in the file the user might expect all the matrices in there.
> > > you use
> > >   0mat_view hdf5:myfile::append
> >    And all the crap from yesterday's runs are also in the file?
> > Barry,
> >   -mat_view binary -vec_view binary:::append
> >     Matt
> > >    Matt
> > > Perhaps PetscOptionsGetViewer() needs to register all viewers created
> with the destroy in PetscFinalize() and never have the user destroy them
> and attach them to the communicator so they get reused at the next call
> instead of creating a new one.
> > >   Even if we do the above another problem is
> > >    -xxx_view xx:filename
> > > will be problematic if there are xxx in different communicators since
> if we attach them to a communicator we won't find them with a different
> communicator and will open the file again. I don't know how to fix this.
> > >   I think the entire PetscOptionsGetViewer() business needs a bit more
> thought. At the moment it is a bit flawed. Making them non-singletons won't
> fix the flaws.
> > > > BTW all PETSC_VIEWER_XXX_() manpages say "Creates a XXX PetscViewer
> shared by all processors in a communicator."
> > > > This is apparently not true - they are singletons stashed to the
> communicator by MPI_Comm_set_attr() and next time reused if found using
> MPI_Comm_get_attr(), right?
> > > > So it should be Returns, not Creates.
> > >   This should be fixed in its own PR.
> > > > On May 28, 2019, at 10:35 AM, Hapla Vaclav via petsc-dev <
> > > > Let me follow up discussion on creating/controlling viewers from
> options.
> > > > Barry agrees to rename PetscOptionsGetViewer() to
> PetscViewerCreateFromOptions() in Issue #291.
> > > > But now I can see a problem: it mixes Get and Create behavior, as it
> returns the singleton provided by PETSC_VIEWER_*_() if possible, otherwise
> creates a new viewer using PetscViewerCreate(). So actually both names
> PetscOptionsGetViewer() and PetscViewerCreateFromOptions() are confusing.
> > > > I think this design is unnecessarily complicated and not really
> useful.
> > > > I don't see any advantage of reusing the singleton in this context.
> > > > And leads to some IMHO unexpected behavior:
> > > > * -myviewer hdf5:: and -myviewer hdf5 is not the same! I didn't know
> that but hdf5:: creates a new viewer and hdf5 reuses the singleton.
> > > > * Any properties (including options prefix) set to the viewer
> returned by PetscOptionsGetViewer() actually affect the singleton and vice
> versa.
> > > >   (See https://bitbucket.org/petsc/petsc/commits/324f959)
> > > > So in my opinion PetscOptionsGetViewer()
> > > > * should really be renamed PetscViewerCreateFromOptions(),
> > > > * should _always_ return a new instance and call
> PetscViewerSetFromOptions() on it,
> > > > * could also set the passed prefix to the viewer, i.e.
> PetscViewerCreateFromOptions(comm, options, "pre_", ...) would result in
> the viewer having prefix pre_
> > > > Do you think it would break anything?
> > > > Thanks,
> > > > Vaclav
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190528/37f5eaf7/attachment-0001.html>
