[petsc-dev] PETSC_VIEWER_*_() vs PetscOptionsGetViewer()
    Matthew Knepley
    knepley at gmail.com
    Tue May 28 16:40:42 CDT 2019
On Tue, May 28, 2019 at 5:26 PM Smith, Barry F. via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
>   I have concerns.
>   Without the use of singletons
>    -mat_view binary -vec_view binary
>   will result in only the final object viewed being in the file
> binaryoutput? The idea behind the singletons is they provide continuity for
> the entire run.
>   Note that currently when also creating and destroying the viewers with
> the same name you only get the most recent stuff. In fact something like
>    -mat_view hdf5:myfile
>   is likely now buggy since it will only save the most recent matrix
> viewed in the file the user might expect all the matrices in there.
you use
  0mat_view hdf5:myfile::append
   Matt
> Perhaps PetscOptionsGetViewer() needs to register all viewers created with
> the destroy in PetscFinalize() and never have the user destroy them and
> attach them to the communicator so they get reused at the next call instead
> of creating a new one.
>   Even if we do the above another problem is
>    -xxx_view xx:filename
> will be problematic if there are xxx in different communicators since if
> we attach them to a communicator we won't find them with a different
> communicator and will open the file again. I don't know how to fix this.
>   I think the entire PetscOptionsGetViewer() business needs a bit more
> thought. At the moment it is a bit flawed. Making them non-singletons won't
> fix the flaws.
> > BTW all PETSC_VIEWER_XXX_() manpages say "Creates a XXX PetscViewer
> shared by all processors in a communicator."
> > This is apparently not true - they are singletons stashed to the
> communicator by MPI_Comm_set_attr() and next time reused if found using
> MPI_Comm_get_attr(), right?
> > So it should be Returns, not Creates.
>   This should be fixed in its own PR.
> > On May 28, 2019, at 10:35 AM, Hapla Vaclav via petsc-dev <
> > Let me follow up discussion on creating/controlling viewers from options.
> > Barry agrees to rename PetscOptionsGetViewer() to
> PetscViewerCreateFromOptions() in Issue #291.
> > But now I can see a problem: it mixes Get and Create behavior, as it
> returns the singleton provided by PETSC_VIEWER_*_() if possible, otherwise
> creates a new viewer using PetscViewerCreate(). So actually both names
> PetscOptionsGetViewer() and PetscViewerCreateFromOptions() are confusing.
> > I think this design is unnecessarily complicated and not really useful.
> > I don't see any advantage of reusing the singleton in this context.
> > And leads to some IMHO unexpected behavior:
> > * -myviewer hdf5:: and -myviewer hdf5 is not the same! I didn't know
> that but hdf5:: creates a new viewer and hdf5 reuses the singleton.
> > * Any properties (including options prefix) set to the viewer returned
> by PetscOptionsGetViewer() actually affect the singleton and vice versa.
> >   (See https://bitbucket.org/petsc/petsc/commits/324f959)
> > So in my opinion PetscOptionsGetViewer()
> > * should really be renamed PetscViewerCreateFromOptions(),
> > * should _always_ return a new instance and call
> PetscViewerSetFromOptions() on it,
> > * could also set the passed prefix to the viewer, i.e.
> PetscViewerCreateFromOptions(comm, options, "pre_", ...) would result in
> the viewer having prefix pre_
> > Do you think it would break anything?
> > Thanks,
> > Vaclav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190528/3e5a567a/attachment.html>
