Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> writes: > These two are definitely wrong, we need PETSC_HAVE_MPI_XXX instead. Thanks, we can delete both of these cpp guards. > include/petscsf.h:#if defined(MPI_REPLACE) MPI-2.0 > src/sys/objects/init.c:#if defined(PETSC_USE_64BIT_INDICES) || > !defined(MPI_2INT) MPI-1.0
