[petsc-dev] PETSc blame digest (next-tmp) 2019-05-20
Smith, Barry F.
bsmith at mcs.anl.gov
Mon May 20 22:16:11 CDT 2019
Fixed. Ready to be merged back into next or next tmp
> On May 20, 2019, at 3:28 PM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing. Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
> The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/3423f38
> Introduces a new Mat class that consists of a single constant value for all entries of the diagonal.
> src/mat/impls/cdiagonal/cdiagonal.c:49
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-pkgs-opt_crank.log]
> /sandbox/petsc/petsc.next-tmp/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-gcc-ifc-cmplx_crank.log]
> /sandbox/petsc/petsc.next-tmp-2/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-freebsd-cxx-pkgs-opt_wii.log]
> /usr/home/balay/petsc.next-tmp-2/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-pkgs-valgrind_es.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-without-fc_si.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-cuda-single_es.log]
> /sandbox/petsc/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-matlab-ilp64-gcov_thrash.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-c-exodus-dbg-builder_frog.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-gcov_cg.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-cmplx-single_si.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-viennacl_frog.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-freebsd-pkgs-opt_wii.log]
> /usr/home/balay/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-opt-misc_el6.log]
> /home/sandbox/petsc/petsc.next-tmp/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-xsdk-dbg_cg.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-IPL64_thrash.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-cuda-double_frog.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-pkgs-64idx_thrash.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
> /usr/home/balay/petsc.next-tmp/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-pkgs-cxx-mlib_el6.log]
> /home/sandbox/petsc/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-dbg-quad_churn.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-opt-cxx-quad_grind.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-cmplx-gcov_si.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-gcc-cxx-avx2_knl.log]
> /home/petsc/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:49:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-uni_crush.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/05/20/build_next-tmp_arch-linux-pkgs-gcov_cg.log]
> src/mat/impls/cdiagonal/cdiagonal.c:99
> /sandbox/petsc/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /usr/home/balay/petsc.next-tmp/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /sandbox/petsc/petsc.next-tmp/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /home/sandbox/petsc/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /sandbox/petsc/petsc.next-tmp-2/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /usr/home/balay/petsc.next-tmp-2/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /usr/home/balay/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /home/petsc/petsc.next-tmp-3/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> /home/sandbox/petsc/petsc.next-tmp/src/mat/impls/cdiagonal/cdiagonal.c:99:24: warning: variable 'ierr' set but not used [-Wunused-but-set-variable]
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/4e78640
> bk-changeset-1.3552.1.11
> include/petsc/private/petscimpl.h:454
> /sandbox/petsc/petsc.next-tmp-3/include/petsc/private/petscimpl.h:454:54: warning: right-hand operand of comma expression has no effect [-Wunused-value]
> /sandbox/petsc/petsc.next-tmp/include/petsc/private/petscimpl.h:454:54: warning: right-hand operand of comma expression has no effect [-Wunused-value]
> /sandbox/petsc/petsc.next-tmp-2/include/petsc/private/petscimpl.h:454:54: warning: right-hand operand of comma expression has no effect [-Wunused-value]
> /usr/home/balay/petsc.next-tmp-3/include/petsc/private/petscimpl.h:454:54: warning: right-hand operand of comma expression has no effect [-Wunused-value]
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
