[petsc-dev] reading gmsh into DMPlex
Adrian Croucher a.croucher at auckland.ac.nz
Wed May 15 21:59:52 CDT 2019
hi
A couple of years ago (see below) I was having problems reading in GMSH
files using DMPlexCreateFromFile(), if the MSH file didn't have a
newline on the end.
It was fixed at the time, but the problem seems to be happening again
with PETSc 3.11.1.
I've attached an example mesh which no longer works (unless you add a
newline on the end of it). The error message is below.
- Adrian
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: File is not a valid Gmsh file, expecting $EndElements
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.11.1-701-g5065da2f63
GIT Date: 2019-05-13 01:43:35 -0
500
[0]PETSC ERROR: ./plexview on a linux-gnu-c-opt named en-354401 by
acro018 Thu May 16 14:54:13 2019
[0]PETSC ERROR: Configure options --with-x --download-hdf5
--download-zlib --download-pnetcdf --download-
netcdf --download-exodusii --download-triangle --download-ptscotch
--download-chaco --download-hypre --wi
th-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
CXXOPTFLAGS="-O3 -march=native -mtune=native"
FOPTFLAGS="-O3 -march=native -mtune=native"
[0]PETSC ERROR: #1 GmshExpect() line 80 in
/home/acro018/software/PETSc/code/src/dm/impls/plex/plexgmsh.c
[0]PETSC ERROR: #2 GmshReadEndSection() line 108 in
lexgmsh.c
[0]PETSC ERROR: #3 DMPlexCreateGmsh() line 1107 in
exgmsh.c
[0]PETSC ERROR: #4 DMPlexCreateGmshFromFile() line 989 in
plex/plexgmsh.c
[0]PETSC ERROR: #5 DMPlexCreateFromFile() line 3268 in
x/plexcreate.c
[0]PETSC ERROR: #6 User provided function() line 0 in User file
On 17/01/17 4:32 PM, Matthew Knepley wrote:
> On Mon, Jan 16, 2017 at 9:15 PM, Adrian Croucher
> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>     hi Matt
>     On 17/01/17 15:52, Matthew Knepley wrote:
>>     Its a DOS file and has no newline at the end. Thus, when I read
>>     $EndElements, it has no termination and you
>>     can something weird. I put a newline on that line and its fine.
>     I don't think it is a DOS file- it was created on a Linux machine,
>     emacs doesn't identify it as DOS, and I tried running dos2unix on
>     it to make sure, but that made no difference.
>     What does make a difference is manually adding a newline on the
>     end. However, that isn't super convenient when these files are
>     being created automatically via scripts.
>     Would it be possible to make DMPlexCreateGmsh() a bit more robust
>     about the line ending at the end of the file? Gmsh itself isn't
>     bothered by it.
> Yes, that was lazy. The fix is in next.
>  Thanks,
>     Matt
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190516/1a5c3062/attachment.html>
Type: model/mesh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190516/1a5c3062/attachment.msh>
