[petsc-dev] [petsc-maint] circular dependency [nightlybuilds did not catch]
Jed Brown jed at jedbrown.org
Sat May 4 12:49:26 CDT 2019
"Smith, Barry F. via petsc-maint" <petsc-maint at mcs.anl.gov> writes:
>   Yes you have the history exactly right, but keeping them as independent beasts seemed/seems impossible; except by doing something very cumbersome (like shoving all the PCXXX_YYY that depended on KSP into the KSP src directory). So the "opted" was really forced upon us.
We could merge PC and KSP into a single class, perhaps maintaining
separate lists by typical "role" (the things we call PC are usually
configured to be linear operations while the things we call KSP are
iterative).  It would be a major change and I'm not suggesting we
should, but it would eliminate a lot of duplication and associated
controversy.
