[petsc-dev] [petsc-maint] circular dependency [nightlybuilds did not catch]
Jed Brown
jed at jedbrown.org
Sat May 4 06:21:31 CDT 2019
Noting this historic event of Barry endorsing the addition of a new
acronym with no specific demonstrated need.
Note that most/all packages contain objects other that that which they
are named after. ksp/pc/, dm/label/, mat/partition/, snes/linesearch,
etc.
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> Ok
>> On May 4, 2019, at 12:45 AM, Václav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>> 4. května 2019 1:08:09 GMT+03:00, "Smith, Barry F." <bsmith at mcs.anl.gov> napsal:
>>>> On May 3, 2019, at 5:00 PM, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
>>> wrote:
>>>> OK, so index, idx, other idea?
>>> I'm not sure index is that informative (and not expansive enough).
>>> petscdm.h means nothing, maybe something short that doesn't mean
>>> anything?
>> Ok, that directly suggests im. One can interpret is as index mapping/management.
>>>> If we would have layout, is, sf, section in the same subdir, I would
>>> move there also ao and ltog.
>>> Sure
>>>> What about the headers - I guess having all those classes in one
>>> would be easier to handle and avoid circular dependencies, and would
>>> reflect the directory structure. But should we keep separate
>>> petsc{ao,is,sf}.h, then I would suggest also separate
>>> petsc{layout,section,ltog}.h
>>> Separate is better.
>>>> When we are at it, why we sometimes have <class>types.h and sometimes
>>> not?
>>> We add these "as needed"; Jed can explain better exactly when they are
>>> needed.
>>>> Vaclav
>>>> (added CC to petsc-dev)
>>>>>> map
>>>>>> imap
>>>>>> idxmap
>>>>>> ... or something alike.
>>>>>> Vaclav
>>>>>>>> Vaclav
>>>>>>>>> Why not at lest make an additional level between Sys and Vec for
>>> those sectioning utilities? Would make more sense to me.
>>>>>>>>> Vaclav
