[petsc-dev] [petsc-maint] circular dependency [nightlybuilds did not catch]
Václav Hapla vaclav.hapla at erdw.ethz.ch
Sat May 4 00:45:09 CDT 2019
4. května 2019 1:08:09 GMT+03:00, "Smith, Barry F." <bsmith at mcs.anl.gov> napsal:
>> On May 3, 2019, at 5:00 PM, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch>
>wrote:
>> OK, so index, idx, other idea?
>I'm not sure index is that informative (and not expansive enough).
>petscdm.h means nothing, maybe something short that doesn't mean
>anything?
Ok, that directly suggests im. One can interpret is as index mapping/management.
>> If we would have layout, is, sf, section in the same subdir, I would
>move there also ao and ltog.
>  Sure
>> What about the headers - I guess having all those classes in one
>would be easier to handle and avoid circular dependencies, and would
>reflect the directory structure. But should we keep separate
>petsc{ao,is,sf}.h, then I would suggest also separate
>petsc{layout,section,ltog}.h
>  Separate is better.
>> When we are at it, why we sometimes have <class>types.h and sometimes
>not?
>We add these "as needed"; Jed can explain better exactly when they are
>needed.
>> Vaclav
>> (added CC to petsc-dev)
>>>> map
>>>> imap
>>>> idxmap
>>>> ... or something alike.
>>>> Vaclav
>>>>>> Vaclav
>>>>>>> Why not at lest make an additional level between Sys and Vec for
>those sectioning utilities? Would make more sense to me.
>>>>>>> Vaclav
