[petsc-dev] [petsc-maint] circular dependency [nightlybuilds did not catch]
Smith, Barry F. bsmith at mcs.anl.gov
Fri May 3 17:08:09 CDT 2019
> On May 3, 2019, at 5:00 PM, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> wrote:
> OK, so index, idx, other idea?
   I'm not sure index is that informative (and not expansive enough). petscdm.h means nothing, maybe something short that doesn't mean anything?
> If we would have layout, is, sf, section in the same subdir, I would move there also ao and ltog.
  Sure
> What about the headers - I guess having all those classes in one would be easier to handle and avoid circular dependencies, and would reflect the directory structure. But should we keep separate petsc{ao,is,sf}.h, then I would suggest also separate petsc{layout,section,ltog}.h
  Separate is better.
> When we are at it, why we sometimes have <class>types.h and sometimes not?
  We add these "as needed"; Jed can explain better exactly when they are needed.
> Vaclav
> (added CC to petsc-dev)
>>> map
>>> imap
>>> idxmap
>>> ... or something alike.
>>> Vaclav
>>>>> Vaclav
>>>>>> Why not at lest make an additional level between Sys and Vec for those sectioning utilities? Would make more sense to me.
>>>>>> Vaclav
