[petsc-dev] alternatives to alt files
Smith, Barry F. bsmith at mcs.anl.gov
Fri May 3 16:31:12 CDT 2019
  My point is that we don't really need patch. Just keep
> tests/output
>            /ex1.out
>            /ex1-1.diff
>            /ex1-2.diff
  Compute the diff between the output and ex1.out if it is not null diff with  /ex1-1.diff etc until it finds match. Not earth shattering.
  I definitely want something like KEEPDIFF option for the test harness to automatically save the diff appropriately. It is a pain to save the file in the appropriate directory manually and since the test harness "knows" where they are from it can do it.
   Barry
> On May 3, 2019, at 4:23 PM, Scott Kruger <kruger at txcorp.com> wrote:
> On 5/3/19 3:13 PM, Smith, Barry F. wrote:
>>> On May 3, 2019, at 3:57 PM, Scott Kruger <kruger at txcorp.com> wrote:
>>> Sticking to the immediate issues and ignoring the other meta issues...
>>> I think what you want could possibly be used to simplify the test harness if we push things down to the petscdiff level. If we
>>> have petscdiff detect the diff then it will automatically apply
>>> the patches.  This would eliminate the "alt" files from the test
>>> harness level.
>>   This could be fine. One could maybe even get away without using the patch tool but simply store the diffs that appear and compare the diff with the basic version against the stored diffs.
> I'm not sure understand this.
> I was thinking of something like:
> tests/output
>            /ex1.out
>            /ex1-1.patch
>            /ex1-2.patch
> And then have petscdiff automaticall cycle through the patches (by patching into the local directory to avoid polluting the original repo).
> The "update feature" of petscdiff shouldn't create patches, but it would be nice to have it automate the patch management in some way to try and make it a bit easier to develop tests).
> Scott
>>> Of course, petscdiff is in bash and we've talked about replacing
>>> it with a python version.  Matt has said he has a preliminary version
>>> and I'd appreciate being able to use this as a starting point.
>>> Scott
>>> On 5/2/19 3:59 PM, Smith, Barry F. wrote:
>>>>    Scott and PETSc folks,
>>>>      Using alt files for testing is painful. Whenever you add, for example, a new variable to be output in a viewer it changes the output files and you need to regenerate the alt files for all the test configurations. Even though the run behavior of the code hasn't changed.
>>>>     I'm looking for suggestions on how to handle this kind of alternative output in a nicer way (alternative output usually comes from different iterations counts due to different precision and often even different compilers).
>>>>     I idea I was thinking of was instead of having "alt" files we have "patch" files that continue just the patch to the original output file instead of a complete copy. Thus in some situations the patch file would still apply even if the original output file changed thus requiring much less manual work in updating alt files. Essentially the test harness would test against the output file, if that fails it would apply the first patch and compare again, try the second patch etc.
>>>>   Scott,
>>>>      What do you think? Should be an easy addition to the current model (no need to even remove the alt testing)? Would it also be possible to add a PATCH option to the test rule where it automatically added the new patch file? Perhaps all the patches for a test case could all be stored in the same file also so we don't need to manage patch_1.out patch_2.out etc? Each new patch would just get added to the file?
>>>>     Thoughts?
>>>>    Barry
>>> Tech-X Corporation               kruger at txcorp.com
>>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>>> Boulder, CO 80303                Fax:   (303) 448-7756
