[petsc-dev] [petsc-users] Bad memory scaling with PETSc 3.10
Mark Adams
mfadams at lbl.gov
Tue Mar 26 18:25:29 CDT 2019
> The way to reduce the memory is to have the all-at-once algorithm (Mark is
> an expert on this). But I am not sure how efficient it could be
> implemented.
I have some data from a 3D elasticity problem with 1.4B equations on:
/home1/04906/bonnheim/olympus-keaveny/Olympus/olympus.petsc-3.9.3.skx-cxx-O
on a skx-cxx-O named c478-062.stampede2.tacc.utexas.edu with 4800
processors, by bonnheim Fri Mar 15 04:48:27 2019
Using Petsc Release Version 3.9.3, unknown
I assume this is on 100 Skylake nodes, but not sure.
Using the all-at-once algorithm in my old solver Prometheus. There are six
levels and thus 5 RAPs. The time for these RAPs is about 150 Mat-vecs on
the fine grid.
The total flop rate for these 5 RAPs was about 4x the flop rate for these
Mat-vecs on the fine grid. This to be expected as the all-at-once algorithm
is simple and not flop optimal and has high arithmetic intensity.
There is a fair amount of load imbalance in this RAP, but the three
coarsest grids have idle processes. The max/min was 2.6 and about 25% of
the time was in the communication layer. (hand written communication layer
that I wrote in grad school)
The fine grid Mat-Vecs had a max/min of 3.1.
Anyway, I know this is not very precise data, but maybe it would help to
(de)motivate its implementation in PETSc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190326/1da3576e/attachment.html>
