[petsc-dev] MatNest and FieldSplit
    Matthew Knepley
    knepley at gmail.com
    Sun Mar 24 15:32:17 CDT 2019
On Sun, Mar 24, 2019 at 10:21 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> It’s a 4x4 matrix.
> The first 2x2 diagonal matrix is a field.
> The second 2x2 diagonal matrix is another field.
> In the second field, the first diagonal coefficient is a subfield.
> In the second field, the second diagonal coefficient is another subfield.
> I’m changing the operators from the second subfield (last diagonal
> coefficient of the matrix).
> When I solve a system with the complete matrix (2 fields), I get a
> different “partial solution" than when I solve the “partial system” on just
> the second field (with the two subfields in which I modified the operators
> from the second one).
I may understand waht you are doing.
Fieldsplit calls MatGetSubMatrix() which can copy values, depending on the
implementation,
so changing values in the original matrix may or may not change it in the
PC.
   Matt
I don’t know if this makes more or less sense… sorry :\
> Thanks,
> Pierre
> On 24 Mar 2019, at 8:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Mar 23, 2019 at 9:12 PM Pierre Jolivet via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> I’m trying to figure out why both solutions are not consistent in the
>> following example.
>> Is what I’m doing complete nonsense?
> The code does not make clear what you are asking. I can see its a nested
> fieldsplit.
>   Thanks,
>      Matt
>> Thanks in advance for your help,
>> Pierre
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190324/76e06c9d/attachment.html>
