[petsc-dev] MPI_UB is deprecated in MPI-2.0
Balay, Satish
balay at mcs.anl.gov
Fri Mar 22 15:40:07 CDT 2019
Thanks! tested in next-tmp and merged to master now.
Satish
On Thu, 21 Mar 2019, Zhang, Junchao wrote:
> I pushed an update to this branch, which adopts MPI_Type_create_resized.
> --Junchao Zhang
> On Tue, Mar 19, 2019 at 11:56 AM Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> For now - I'm merging this branch to next. If better fix comes up later we can merge
> it then.
> thanks,
> Satish
> On Wed, 13 Mar 2019, Isaac, Tobin G wrote:
> > Pushed a fix that just uses MPI_Type_contiguous(MPI_BYTE, sizeof(),
> > ...), which is not great but I'm only creating the type to work with
> > PetscSF, so it does the job. Satish, do you want this as a pull
> > request, or can you just merge it into next
> > (`tisaac/feature-remove-mpi-ub`)?
> > Thanks,
> > Toby
> > On Tue, Mar 12, 2019 at 10:21:42PM -0600, Jed Brown wrote:
> > > MPI_Type_create_resized (if needed).
> > > "Balay, Satish via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> > > >http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/03/01/make_master_arch-linux-pkgs-64id
> x_thrash.log
> > > > has the following [but for some reason - its filtered out from the warning
> count]
> > > > In file included from
> /sandbox/petsc/petsc.master-3/src/dm/impls/forest/p4est/dmp4est.c:13:0:
> > > > /sandbox/petsc/petsc.master-3/src/dm/impls/forest/p4est/pforest.c: In function
> ‘DMPforestGetTransferSF_Point’:
> > > > /sandbox/petsc/petsc.master-3/src/dm/impls/forest/p4est/pforest.c:2518:7:
> warning: ‘ompi_mpi_ub’ is deprecated (declared at
> /sandbox/petsc/petsc.master-3/arch-linux-pkgs-64idx/include/mpi.h:928): MPI_UB is
> deprecated in MPI-2.0 [-Wdeprecated-declarations]
> > > > MPI_Datatype blockTypes[5] =
> {MPI_INT32_T,MPI_INT8_T,MPI_INT16_T,MPI_INT32_T,MPI_UB};
> > > > Any idea how to fix this?
> > > > Thanks,
> > > > Satish
