[petsc-dev] MPI_UB is deprecated in MPI-2.0
Balay, Satish
balay at mcs.anl.gov
Tue Mar 19 11:56:50 CDT 2019
For now - I'm merging this branch to next. If better fix comes up later we can merge it then.
thanks,
Satish
On Wed, 13 Mar 2019, Isaac, Tobin G wrote:
> Pushed a fix that just uses MPI_Type_contiguous(MPI_BYTE, sizeof(),
> ...), which is not great but I'm only creating the type to work with
> PetscSF, so it does the job. Satish, do you want this as a pull
> request, or can you just merge it into next
> (`tisaac/feature-remove-mpi-ub`)?
> Thanks,
> Toby
> On Tue, Mar 12, 2019 at 10:21:42PM -0600, Jed Brown wrote:
> > MPI_Type_create_resized (if needed).
> > "Balay, Satish via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> > > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/03/01/make_master_arch-linux-pkgs-64idx_thrash.log
> > > has the following [but for some reason - its filtered out from the warning count]
> > > In file included from /sandbox/petsc/petsc.master-3/src/dm/impls/forest/p4est/dmp4est.c:13:0:
> > > /sandbox/petsc/petsc.master-3/src/dm/impls/forest/p4est/pforest.c: In function ‘DMPforestGetTransferSF_Point’:
> > > /sandbox/petsc/petsc.master-3/src/dm/impls/forest/p4est/pforest.c:2518:7: warning: ‘ompi_mpi_ub’ is deprecated (declared at /sandbox/petsc/petsc.master-3/arch-linux-pkgs-64idx/include/mpi.h:928): MPI_UB is deprecated in MPI-2.0 [-Wdeprecated-declarations]
> > > MPI_Datatype blockTypes[5] = {MPI_INT32_T,MPI_INT8_T,MPI_INT16_T,MPI_INT32_T,MPI_UB};
> > > Any idea how to fix this?
> > > Thanks,
> > > Satish
