[petsc-dev] https://www.dursi.ca/post/hpc-is-dying-and-mpi-is-killing-it.html
    Jeff Hammond
    jeff.science at gmail.com
    Sun Mar 17 19:01:54 CDT 2019
When this was written, I was convinced that Dursi was wrong about
everything because one of the key arguments against MPI was
fault-intolerance, which I was sure was going to be solved soon.  However,
LLNL has done everything in their power to torpedo MPI fault-tolerance in
MPI-4 for the past 3+ years and I am no longer optimistic about MPI's
ability to grow outside of traditional HPC because of the forum's inability
to take fault-tolerance seriously.  It's also unclear that we can get by
without it in a post-exascale world.
Jeff
On Sun, Mar 17, 2019 at 4:33 PM Matthew Knepley via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> On Sun, Mar 17, 2019 at 5:34 PM Jed Brown via petsc-dev <
>> "Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
>> >   I stubbled on this today; I should have seen it years ago.
>> https://lists.mpich.org/pipermail/devel/2015-April/000536.html
>> https://twitter.com/KpDooty/status/585763759777574912
>> Proposing, as replacements for MPI, systems with no successful libraries
>> is a strange hill to die on.  I'd like a system with more flexible
>> process management and better support/conventions for interactive
>> environments (where interrupts and programming bugs are common).  That
>> would help reduce impedance mismatch between MPI and the likes of Spark
>> and Dask.  Any discussion of such tools should include an explanation of
>> why MPI has been/is used by machine learning groups including Watson,
>> Baidu, Bing, and OpenAI.
> I wasted 30s skimming this. I should has used that to recognize the author
> as a member of the FLASH team before reading.
>    Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190317/f6345a7b/attachment.html>
