[petsc-dev] Size of " PetscInt *garray" in Mat_MPIAIJ
Fande Kong
fdkong.jd at gmail.com
Thu Mar 14 17:28:00 CDT 2019
Does mat->cmap->N= mat->A->cmap->N + mat->B->cmap->N??
I maybe misunderstand this.
Fande,
On Thu, Mar 14, 2019 at 4:09 PM Jed Brown <jed at jedbrown.org> wrote:
> Fande Kong via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > Hi Developers,
> > What is the size of " PetscInt *garray" in Mat_MPIAIJ? Will it be
> > mat->B->cmap->N?
> Yes.
> > If so, it is not scalable in terms of the problem size, right? I am
> > missing something here.
> No, B only has columns for off-process entries where there are nonzeros.
> It's only a scalability issue if you have dense rows, in which case you
> have bigger problems on communication and should not use 1D matrix
> decompositions.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190314/ce56532e/attachment.html>
