[petsc-dev] errors with cuda + mumps
Zhang, Junchao jczhang at mcs.anl.gov
Wed Mar 13 17:10:58 CDT 2019
search='snes_tutorials-ex69_q2p1fetidp_deluxe snes_tutorials-ex62_fetidp_2d_quad snes_tutorials-ex69_q2p1fetidp_deluxe_adaptive ksp_ksp_tutorials-ex52f_mumps'
Already made a PR.
--Junchao Zhang
On Wed, Mar 13, 2019 at 4:55 PM Balay, Satish <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
On Wed, 13 Mar 2019, Zhang, Junchao wrote:
> On Wed, Mar 13, 2019 at 3:49 PM Balay, Satish <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
>       mailers that only format html and not the text form are annoying :(
>       > Satish,   I found something strange. I configured with --with-cuda --with-precision=single, then
>       with -log_view, I saw
>       >       Compiled with single precision PetscScalar and PetscReal
>       > Compiled with full precision matrices (default)
>       This message is misleading [and should be fixed]. This feature was removed.
>       >   I found that confused mumps. When I added --with-precision=double, I got consistent MatScalar
>       and PetscScalar precision, and the errors I reported
>       > disappeared. Do you know why?
>       how is mumps confused? Perhaps this example doesn't work with single precision? [or mumps single
>       precision doesn't work for this problem?]
>  OK, I thought mumps was inputed with a double precision matrix and single precision vectors.  I was wrong.  I
> tested on my laptop --with-cuda --with-precision=single, these errors did show up.  In petsc dashboard, we do
> not have "single + mumps" combination.  I will create a PR to mark these tests require double.
Which examples are you referring to? Do they fail in master - or only in your feature branch?
Satish
>       Lots of examples fail with single precision..
>       Satish
>       > --Junchao Zhang
>       > On Wed, Mar 13, 2019 at 11:15 AM Junchao Zhang <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> wrote:
>       >       I met some errors with cuda + mumps. It was tested with
>       >       make -f gmakefile test search='snes_tutorials-ex69_q2p1fetidp_deluxe
>       > I can reproduce it with petsc master.  The first line of petsc nightly
>       > (http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/03/12/master.html) shows another
>       error. But I guess they have the same root: PETSc
>       > gives random wrong results in some cases. For example, I ran ksp_ksp_tutorials-ex52f_mumps twice
>       and saw
>       >       $ mpirun -n 3 ./ex52f
>       > Mumps row pivot threshhold =    1.00E-06
>       > Mumps determinant=(   9.01E-01   0.00E+00)*2^ 99
>       > Norm of error  1.5554E-06 iterations     1
>       > Norm of error  1.6356E-06 iterations     1
>       > The correct output has "Norm of error < 1.e-12,iterations     1".  Currently, I do know the
>       reason.
>       > --Junchao Zhang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190313/f595a3ad/attachment.html>
