[petsc-dev] errors with cuda + mumps
Matthew Knepley
knepley at gmail.com
Wed Mar 13 11:26:47 CDT 2019
On Wed, Mar 13, 2019 at 12:16 PM Zhang, Junchao via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> I met some errors with cuda + mumps.
It does not look like CUDA is being used in these runs. Is it? If not, do
you mean MUMPS goes crazy if we even compiler something with CUDA?
Matt
> It was tested with
> make -f gmakefile test search='snes_tutorials-ex69_q2p1fetidp_deluxe
> snes_tutorials-ex62_fetidp_2d_quad
> snes_tutorials-ex69_q2p1fetidp_deluxe_adaptive
> ksp_ksp_tutorials-ex52f_mumps'
> I can reproduce it with petsc master. The first line of petsc nightly (
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2019/03/12/master.html)
> shows another error. But I guess they have the same root: PETSc gives
> random wrong results in some cases. For example, I ran
> ksp_ksp_tutorials-ex52f_mumps twice and saw
> $ mpirun -n 3 ./ex52f
> Mumps row pivot threshhold = 1.00E-06
> Mumps determinant=( 9.01E-01 0.00E+00)*2^ 99
> *Norm of error 1.5554E-06 iterations 1*
> *Norm of error 1.6356E-06 iterations 1 *
> The correct output has "*Norm of error < 1.e-12,iterations 1*".
> Currently, I do know the reason.
> --Junchao Zhang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190313/af17fcfd/attachment.html>
