[petsc-dev] Getting Richardson output
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Mar 11 21:12:31 CDT 2019
Hmm, the self scale should force the non-special Richardson apply anyways.
Maybe have the user run with same options but a smoother of GMRES and see if the inner monitor works then?
Barry
> On Mar 11, 2019, at 9:04 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 11, 2019 at 9:59 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Richardson has this "special case where it calls PCApplyRichardson() under certain circumstances (for efficiency) but KSPSolve_Richardson() has the check
> if (exists && maxit > 0 && richardsonP->scale == 1.0 && !ksp->numbermonitors && !ksp->transpose_solve && !nullsp) {
> so if monitoring is turned on it should run "the regular way" and call the monitor. I don't think there is any special code associated with its use in multigrid so I would expect it to work. I guess you need to check in the debugger why it is not following the appropriate route.
> Hmm. I can't see inside this users code, but the output is not printing for some reason. Take a look at the attached.
> Matt
> Barry
> Also check that it is not running with preonly which has its own special case.
> > On Mar 11, 2019, at 8:45 PM, Matthew Knepley via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > Does Richardson not respond to -mg_levels_ksp_monitor by default? If so, how do you turn it on?
> > Thanks,
> > Matt
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> -- Norbert Wiener
> <output.txt>
