[petsc-dev] PETSc release by March 29, 2019
    Karl Rupp
    rupp at iue.tuwien.ac.at
    Tue Mar  5 11:03:45 CST 2019
> - its best to submit PRs early - if they are critical [i.e if the
> branch should be in release] - or if they are big - and likely to
> break builds.
> - we should somehow use both next and next-tmp in a way to avoid some
>    PRs clogging the process for others.
>    perhaps starting March 18 - freeze access to next - and keep
>    recreating next & next-tmp dynamically as needed with the goal of
>    testing fewer branches together (ideally 1 branch at a time) - so
>    that we can:
>     * easily identify the branch corresponding to test failures and
>     * easily identify branchs that are ready for graduation.
I can be more aggressive with reverting merges until the branches are
fixed. It's a bit more effort, but certainly justified closer to the
release. Usually it's not a big problem to have 2-3 new (smallish) PRs
in next.
> - We should accept (minor?) bug-fix PRs even after March 22 [i.e
>    anything that would be acceptable in our maint work-flow shouldn't
>    be frozen]
> - And we should be able to drop troublesome PRs if they are blocking
>    the release.
full ack :-)
Best regards,
Karli
> Satish
> On Tue, 5 Mar 2019, Karl Rupp via petsc-dev wrote:
>> Dear PETSc developers,
>> let me suggest Friday, March 22, as the cut-off-date for new Pull Requests for
>> the upcoming release. This allows for 7 days to iron out any remaining
>> glitches. (It only took us a few days to release after the cut-off date last
>> September, so this should be fine)
>> Also, a clearly communicated cut-off date helps to prevent "may I also squeeze
>> this in at the very last minute"-PRs, which I may not have the time to deal
>> with anyway.
>> Satish, does the above schedule work for you? Since you're creating the
>> tarballs, you've got the final word on this :-)
>> Best regards,
>> Karli
>> On 3/4/19 4:31 AM, Smith, Barry F. via petsc-dev wrote:
>>>     Due to ECP deliverables there will be a PETSc release by March 29, 2019.
>>>     Please prepare materials you wish to get into the release soon and check
>>> on the progress of your current pull requests to make sure they do not block
>>> beyond the release deadline.
>>>       Thanks
>>>        Barry
>>>     If someone would like to propose an intermediate deadline before the 29th
>>> for testing/etc purposes please feel free, I don't have the energy or
>>> initiative.
>>>> Begin forwarded message:
>>>> *From: *Jed Brown via petsc-maint <petsc-maint at mcs.anl.gov
>>>> <mailto:petsc-maint at mcs.anl.gov>>
>>>> *Subject: **Re: [petsc-maint] Release 3.11?*
>>>> *Date: *March 3, 2019 at 10:07:26 AM CST
>>>> *To: *"Munson, Todd" <tmunson at mcs.anl.gov <mailto:tmunson at mcs.anl.gov>>
>>>> *Cc: *petsc-maint <petsc-maint at mcs.anl.gov
>>>> *Reply-To: *Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>>
>>>> Can you, or someone else involved at that level, please propose a timeline
>>>> on petsc-dev?
>>>> "Munson, Todd" <tmunson at mcs.anl.gov <mailto:tmunson at mcs.anl.gov>> writes:
>>>>> Hi Jed,
>>>>> Yes, we have a funding milestone due at the end of this month, so we
>>>>> should push out a release.
>>>>> Thanks, Todd.
>>>>>> On Mar 2, 2019, at 11:36 PM, Jed Brown <jed at jedbrown.org
>>>>>> <mailto:jed at jedbrown.org>> wrote:
>>>>>> Is there a funding milestone to release 3.11 this month?  If so, we need
>>>>>> to publicize a timeline and mention it on petsc-dev?  If not, we can
>>>>>> feature release whenever we feel ready, but probably in the next few
>>>>>> months.
