[petsc-dev] Why do we use void* instead of PetscObject in PETSc?
Dave May
dave.mayhem23 at gmail.com
Mon Mar 4 15:41:00 CST 2019
On Mon, 4 Mar 2019 at 21:30, Jed Brown <jed at jedbrown.org> wrote:
> Dave May via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> > I think there would be a lot of merit (in the long run) if user contexts,
> > such as given to KSPSetComputeOperators(), SNESSetJacobian() etc were
> > changed to be of type PetscObject rather than void*.
> > Some obvious benefits would be:
> > [1] Type checking!
> How is passing a void* to PetscObject/PetscContainer different from
> passing it to SNES?
It's not.
The difference is that the void* business would be entirely pushed up into
the user code and moved out of PETSc.
> Also, would you have different types for every
> callback or would you reuse?
Reuse.
> If reusing, would the interface require
> casting the function pointers to void(*)(void) instead of what is
> currently type-safe for most function pointers?
No. I don't see that casting a function pointer would be required.
We would have
SNESSetJacobian(SNES snes,Mat Amat,Mat Pmat,PetscErrorCode
(*J)(SNES,Vec,Mat,Mat,PetscObject),PetscObject ctx)
Maybe I misunderstand your question.
> This feels like less
> rather than more type safety.
> Agree on other points.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190304/eef54fc1/attachment.html>
