[petsc-dev] Note about CPR preconditioner in PCFIELDSPLIT man page?
    Jed Brown
    jed at jedbrown.org
    Sun Mar  3 10:38:09 CST 2019
Matthew Knepley <knepley at gmail.com> writes:
> On Sun, Mar 3, 2019 at 12:58 AM Jed Brown via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> My take is that someone looking for CPR is more likely to end up on the
>> PCFIELDSPLIT manual page than the PCGALERKIN page.  The solver you have
>> configured in your mail is not the CPR we have been asked about here.
>> See Barry's message and example code below.
> Thanks for retrieving this Jed. I am sure Richard and I both have the same
> question. Perhaps I am being an idiot.
> I am supposing that R is just a restriction to some subset of dofs, so its
> just binary, so that R A P just selects that
> submatrix.
Look at the source.  These are not subsets:
     Apply the restriction operator for the Galkerin problem
 PetscErrorCode ApplyR(Mat A, Vec x,Vec y)
   PetscErrorCode ierr;
   PetscInt       b;
   PetscFunctionBegin;
   ierr = VecGetBlockSize(x,&b);CHKERRQ(ierr);
   ierr = VecStrideGather(x,0,y,INSERT_VALUES);CHKERRQ(ierr);
   for (PetscInt k=1;k<b;++k) {ierr = VecStrideGather(x,k,y,ADD_VALUES);CHKERRQ(ierr);}
   PetscFunctionReturn(0);
     Apply the interpolation operator for the Galerkin problem
 PetscErrorCode ApplyP(Mat A, Vec x,Vec y)
   PetscInt       offset = 1;
   PetscFunctionBegin;
   ierr = VecStrideScatter(x,offset,y,INSERT_VALUES);CHKERRQ(ierr);
