[petsc-dev] Unused macros in petscconf.h
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Jun 30 23:42:33 CDT 2019
https://bitbucket.org/petsc/petsc/pull-requests/1834/remove-testing-and-inserting-into/diff
removed about 1/3 of the entries for a build with about 10 external packages
perhaps there are a small number of entries that may still be removed but I think I got rid of most the unneeded ones.
Barry
Left pthread because I would like to use it soon :-)
> On Jun 28, 2019, at 12:37 PM, Jed Brown via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> We have a lot of lines like this
> $ grep -c HAVE_LIB $PETSC_ARCH/include/petscconf.h
> 96
> but only four of these are ever checked in src/. Delete them?
> IMO, unused stuff should not go into petscconf.h. We have to scroll up
> past these lines every time configure crashes. These are apparently all
> unused:
> $ for name in $(grep '#define \w\+ ' $PETSC_ARCH/include/petscconf.h | cut -f 2 -d\ ); do rg -q -c $name include/ src/ || echo $name; done
> STDC_HEADERS
> HAVE_MATH_INFINITY
> ANSI_DECLARATORS
> PETSC_PATH_SEPARATOR
> PETSC_HAVE_BLASLAPACK
> PETSC_HAVE_PTHREAD
> PETSC_HAVE_NETCDF
> PETSC_HAVE_PNETCDF
> PETSC_HAVE_METIS
> PETSC_HAVE_MATHLIB
> PETSC_HAVE_ZLIB
> PETSC_TIME_WITH_SYS_TIME
> PETSC_HAVE_MATH_H
> PETSC_HAVE_ENDIAN_H
> PETSC_HAVE_LIMITS_H
> PETSC_HAVE_SEARCH_H
> PETSC_HAVE_SCHED_H
> PETSC_HAVE_PTHREAD_H
> PETSC_HAVE_CXX_NAMESPACE
> PETSC_HAVE_FORTRAN_TYPE_INITIALIZE
> PETSC_HAVE_LIBDL
> PETSC_HAVE_LIBQUADMATH
> PETSC_HAVE_LIBX11
> PETSC_HAVE_LIBZ
> PETSC_HAVE_LIBTRIANGLE
> PETSC_HAVE_LIBMETIS
> PETSC_HAVE_LIBPARMETIS
> PETSC_HAVE_LIBHDF5HL_FORTRAN
> PETSC_HAVE_LIBHDF5_FORTRAN
> PETSC_HAVE_LIBHDF5_HL
> PETSC_HAVE_LIBHDF5
> PETSC_HAVE_LIBPNETCDF
> PETSC_HAVE_LIBNETCDF
> PETSC_HAVE_LIBEXODUS
> PETSC_HAVE_LIBBLAS
> PETSC_HAVE_LIBLAPACK
> PETSC_HAVE_LIBSTDC__
> PETSC_HAVE_LIBMPI_USEMPIF08
> PETSC_HAVE_LIBMPI_USEMPI_IGNORE_TKR
> PETSC_HAVE_LIBMPI_MPIFH
> PETSC_HAVE_LIBMPI
> PETSC_HAVE_LIBGFORTRAN
> PETSC_HAVE_LIBGCC_S
> PETSC_HAVE_LIBPTHREAD
> PETSC_HAVE_LIBSUNDIALS_CVODE
> PETSC_HAVE_LIBSUNDIALS_NVECSERIAL
> PETSC_HAVE_LIBSUNDIALS_NVECPARALLEL
> PETSC_HAVE_LIBML
> PETSC_HAVE_LIBSUPERLU_DIST
> PETSC_HAVE_LIBUMFPACK
> PETSC_HAVE_LIBKLU
> PETSC_HAVE_LIBCHOLMOD
> PETSC_HAVE_LIBBTF
> PETSC_HAVE_LIBCCOLAMD
> PETSC_HAVE_LIBCOLAMD
> PETSC_HAVE_LIBCAMD
> PETSC_HAVE_LIBAMD
> PETSC_HAVE_LIBSUITESPARSECONFIG
> PETSC_HAVE_LIBSCALAPACK
> PETSC_HAVE_LIBCMUMPS
> PETSC_HAVE_LIBDMUMPS
> PETSC_HAVE_LIBSMUMPS
> PETSC_HAVE_LIBZMUMPS
> PETSC_HAVE_LIBMUMPS_COMMON
> PETSC_HAVE_LIBPORD
> PETSC_HAVE_LIBHYPRE
> PETSC_USE_SCALAR_REAL
> PETSC_HAVE_REAL___FLOAT128
> PETSC_RETSIGTYPE
> PETSC_SIZEOF_SHORT
> PETSC_SIZEOF_MPI_COMM
> PETSC_SIZEOF_MPI_FINT
> PETSC_HAVE_VPRINTF
> PETSC_HAVE_VFPRINTF
> PETSC_HAVE_MKSTEMP
> PETSC_HAVE_GETHOSTBYNAME
> PETSC_HAVE_SOCKET
> PETSC_HAVE_TIMES
> PETSC_HAVE_SIGSET
> PETSC_HAVE_GETTIMEOFDAY
> PETSC_HAVE_SIGNAL
> PETSC_HAVE_GET_NPROCS
> PETSC_HAVE_SIGACTION
> PETSC_HAVE__GFORTRAN_IARGC
> PETSC_HAVE_SHARED_LIBRARIES
> PETSC_USE_GDB_DEBUGGER
> PETSC_VERSION_BRANCH_GIT
> PETSC_HAVE_MPI_COMM_F2C
> PETSC_HAVE_MPI_COMM_C2F
> PETSC_HAVE_MPI_FINT
> PETSC_HAVE_MPI_REPLACE
> PETSC_HAVE_MPI_WIN_ALLOCATE_SHARED
> PETSC_HAVE_MPI_WIN_SHARED_QUERY
> PETSC_HAVE_MPI_ALLTOALLW
> PETSC_HAVE_MPI_COMM_SPAWN
> PETSC_HAVE_MPI_TYPE_GET_EXTENT
> PETSC_HAVE_PTHREAD_BARRIER_T
> PETSC_HAVE_SCHED_CPU_SET_T
> PETSC_HAVE_SYS_SYSCTL_H
> PETSC_LEVEL1_DCACHE_SIZE
> PETSC_LEVEL1_DCACHE_ASSOC
