[petsc-dev] Sowing: proposed change to allow single-entry lists on man pages
    Patrick Sanan
    patrick.sanan at gmail.com
    Sat Jun 29 05:50:55 CDT 2019
That's great! That'll go a long way towards making the man pages look
neater - I'm happy to review the PR that updates the arg lists on the man
pages - is your branch off of master (and thus can be submitted with the
usual procedure of a pull request on bitbucket)?
Am Di., 25. Juni 2019 um 09:05 Uhr schrieb Gropp, William D <
wgropp at illinois.edu>:
> Thanks for this suggestion.  The + and - were added to make it easier to
> generate a nicely formatted list, though its possible to look for
> transitions from non-list to list and back to non-list.  Think of + as
> similar to \begin{description}\item … and - as \item … \end{description}.
> I’ve updated doctext to allow both - and a isolated . for an argument
> description. In the process of doing this, I added checks for errors in the
> use of the doctext formatting, and found many minor errors, as well as
> updating the old arg lists that didn’t use the + .. - . I have a branch for
> petsc that fixes all of those (it was the easiest way for me to be sure my
> doctext fixes worked) that will need to be merged.  Let me know how you’d
> like me to submit that. There are also many malformed entries where there
> is no description.  I’ve turned those warnings off by default, but
> -Wargdesc will warn for each argument that is missing a description; some
> of these should use different formatting instead of the argument lists.
> The new version, in sowing-1.1.26, also has updates to bfort (which
> requires the patch that I sent earlier to bin/maint/generatefortranstubs.py
> ) and other miscellaneous fixes.  I’ve uploaded this version to my web page
> and it is the default when you download sowing.tar.gz .  I am unable to
> update the confdb macros to fix errors in them - the permissions have
> changed on the repository (for my own files!).  Because of that and other
> problems, I plan to move sowing to a git repository that I fully control
> soon; this weekend if I can.
> Let me know if you have any problems.
> Bill
> William Gropp
> Director and Chief Scientist, NCSA
> Thomas M. Siebel Chair in Computer Science
> University of Illinois Urbana-Champaign
> On Jun 15, 2019, at 12:06 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> On Jun 15, 2019, at 11:57 AM, Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
> Great! I'll leave that commit there for reference, but as you say it would
> be even nicer (but more coding) to avoid needing to explicitly mark the
> starts and ends of lists.
>   Yeah, I only remember vaguely that initially we didn't use the + and -
> on the lists and there was some issue so they were introduced.
>  Barry
> Am Sa., 15. Juni 2019 um 17:54 Uhr schrieb Smith, Barry F. <
> bsmith at mcs.anl.gov>:
>  Patrick (and Bill)
>     Good timing. Bill is actually updating Sowing now and could perhaps
> fix this glitch. Currently we use a . for a single entry in the list and
> I'd hate to have to change them all the -. Likely it is possible to fix the
> formatting for the . case to have the same indent as the + . - cases.
>   Barry
> On Jun 15, 2019, at 10:15 AM, Patrick Sanan via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> Lists on the man pages don't seem to be able to have a single entry,
> because sowing requires you to start lists with "+" and end them with "-",
> requiring at least two entries.
> This leads to ugly-looking indentation for man pages for functions with a
> single input or output parameter, e.g.
> https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DMSTAG/DMStagVecGetArrayDOF.html
> I think that this can be remedied with a small change to sowing (doctext),
> to interpret a lone '-' as opening a list (and then closing it after one
> entry):
> https://bitbucket.org/psanan/sowing/commits/780ea53824388e8c6089ae2d6210332c63935edb
> (Posting this here since I'm not sure how closely the
> bitbucket.org/petsc/pkg-sowing repository is monitored)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190629/4855ead3/attachment.html>
