[petsc-dev] Unused macros in petscconf.h
Fri Jun 28 16:13:11 CDT 2019
On Fri, Jun 28, 2019 at 2:04 PM Smith, Barry F. via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
>   You are right, these do not belong in petscconf.h
The problematic thing here is hiding information from users of PETSc. If
you are a user that
counts on PETSc configure to check something, but then we hide it because
we do not use it,
I would not be happy.
    Matt
>  Barry
> > On Jun 28, 2019, at 12:37 PM, Jed Brown via petsc-dev <
> > We have a lot of lines like this
> > $ grep -c HAVE_LIB $PETSC_ARCH/include/petscconf.h
> > 96
> > but only four of these are ever checked in src/.  Delete them?
> > IMO, unused stuff should not go into petscconf.h.  We have to scroll up
> > past these lines every time configure crashes.  These are apparently all
> > unused:
> > $ for name in $(grep '#define \w\+ ' $PETSC_ARCH/include/petscconf.h |
> cut -f 2 -d\ ); do rg -q -c $name include/ src/ || echo $name; done
> > STDC_HEADERS
> > HAVE_MATH_INFINITY
> > ANSI_DECLARATORS
> > PETSC_PATH_SEPARATOR
> > PETSC_HAVE_BLASLAPACK
> > PETSC_HAVE_PTHREAD
> > PETSC_HAVE_NETCDF
> > PETSC_HAVE_PNETCDF
> > PETSC_HAVE_METIS
> > PETSC_HAVE_MATHLIB
> > PETSC_HAVE_ZLIB
> > PETSC_TIME_WITH_SYS_TIME
> > PETSC_HAVE_MATH_H
> > PETSC_HAVE_ENDIAN_H
> > PETSC_HAVE_LIMITS_H
> > PETSC_HAVE_SEARCH_H
> > PETSC_HAVE_SCHED_H
> > PETSC_HAVE_PTHREAD_H
> > PETSC_HAVE_CXX_NAMESPACE
> > PETSC_HAVE_FORTRAN_TYPE_INITIALIZE
> > PETSC_HAVE_LIBDL
> > PETSC_HAVE_LIBQUADMATH
> > PETSC_HAVE_LIBX11
> > PETSC_HAVE_LIBZ
> > PETSC_HAVE_LIBTRIANGLE
> > PETSC_HAVE_LIBMETIS
> > PETSC_HAVE_LIBPARMETIS
> > PETSC_HAVE_LIBHDF5HL_FORTRAN
> > PETSC_HAVE_LIBHDF5_FORTRAN
> > PETSC_HAVE_LIBHDF5_HL
> > PETSC_HAVE_LIBHDF5
> > PETSC_HAVE_LIBPNETCDF
> > PETSC_HAVE_LIBNETCDF
> > PETSC_HAVE_LIBEXODUS
> > PETSC_HAVE_LIBBLAS
> > PETSC_HAVE_LIBLAPACK
> > PETSC_HAVE_LIBSTDC__
> > PETSC_HAVE_LIBMPI_USEMPIF08
> > PETSC_HAVE_LIBMPI_USEMPI_IGNORE_TKR
> > PETSC_HAVE_LIBMPI_MPIFH
> > PETSC_HAVE_LIBMPI
> > PETSC_HAVE_LIBGFORTRAN
> > PETSC_HAVE_LIBGCC_S
> > PETSC_HAVE_LIBPTHREAD
> > PETSC_HAVE_LIBSUNDIALS_CVODE
> > PETSC_HAVE_LIBSUNDIALS_NVECSERIAL
> > PETSC_HAVE_LIBSUNDIALS_NVECPARALLEL
> > PETSC_HAVE_LIBML
> > PETSC_HAVE_LIBSUPERLU_DIST
> > PETSC_HAVE_LIBUMFPACK
> > PETSC_HAVE_LIBKLU
> > PETSC_HAVE_LIBCHOLMOD
> > PETSC_HAVE_LIBBTF
> > PETSC_HAVE_LIBCCOLAMD
> > PETSC_HAVE_LIBCOLAMD
> > PETSC_HAVE_LIBCAMD
> > PETSC_HAVE_LIBAMD
> > PETSC_HAVE_LIBSUITESPARSECONFIG
> > PETSC_HAVE_LIBSCALAPACK
> > PETSC_HAVE_LIBCMUMPS
> > PETSC_HAVE_LIBDMUMPS
> > PETSC_HAVE_LIBSMUMPS
> > PETSC_HAVE_LIBZMUMPS
> > PETSC_HAVE_LIBMUMPS_COMMON
> > PETSC_HAVE_LIBPORD
> > PETSC_HAVE_LIBHYPRE
> > PETSC_USE_SCALAR_REAL
> > PETSC_HAVE_REAL___FLOAT128
> > PETSC_RETSIGTYPE
> > PETSC_SIZEOF_SHORT
> > PETSC_SIZEOF_MPI_COMM
> > PETSC_SIZEOF_MPI_FINT
> > PETSC_HAVE_VPRINTF
> > PETSC_HAVE_VFPRINTF
> > PETSC_HAVE_MKSTEMP
> > PETSC_HAVE_GETHOSTBYNAME
> > PETSC_HAVE_SOCKET
> > PETSC_HAVE_TIMES
> > PETSC_HAVE_SIGSET
> > PETSC_HAVE_GETTIMEOFDAY
> > PETSC_HAVE_SIGNAL
> > PETSC_HAVE_GET_NPROCS
> > PETSC_HAVE_SIGACTION
> > PETSC_HAVE__GFORTRAN_IARGC
> > PETSC_HAVE_SHARED_LIBRARIES
> > PETSC_USE_GDB_DEBUGGER
> > PETSC_VERSION_BRANCH_GIT
> > PETSC_HAVE_MPI_COMM_F2C
> > PETSC_HAVE_MPI_COMM_C2F
> > PETSC_HAVE_MPI_FINT
> > PETSC_HAVE_MPI_REPLACE
> > PETSC_HAVE_MPI_WIN_ALLOCATE_SHARED
> > PETSC_HAVE_MPI_WIN_SHARED_QUERY
> > PETSC_HAVE_MPI_ALLTOALLW
> > PETSC_HAVE_MPI_COMM_SPAWN
> > PETSC_HAVE_MPI_TYPE_GET_EXTENT
> > PETSC_HAVE_PTHREAD_BARRIER_T
> > PETSC_HAVE_SCHED_CPU_SET_T
> > PETSC_HAVE_SYS_SYSCTL_H
> > PETSC_LEVEL1_DCACHE_SIZE
> > PETSC_LEVEL1_DCACHE_ASSOC
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190628/33d40454/attachment.html>
