[petsc-dev] Unused macros in petscconf.h
Jed Brown jed at jedbrown.org
Fri Jun 28 12:37:23 CDT 2019
We have a lot of lines like this
$ grep -c HAVE_LIB $PETSC_ARCH/include/petscconf.h
96
but only four of these are ever checked in src/.  Delete them?
IMO, unused stuff should not go into petscconf.h.  We have to scroll up
past these lines every time configure crashes.  These are apparently all
unused:
$ for name in $(grep '#define \w\+ ' $PETSC_ARCH/include/petscconf.h | cut -f 2 -d\ ); do rg -q -c $name include/ src/ || echo $name; done
STDC_HEADERS
HAVE_MATH_INFINITY
ANSI_DECLARATORS
PETSC_PATH_SEPARATOR
PETSC_HAVE_BLASLAPACK
PETSC_HAVE_PTHREAD
PETSC_HAVE_NETCDF
PETSC_HAVE_PNETCDF
PETSC_HAVE_METIS
PETSC_HAVE_MATHLIB
PETSC_HAVE_ZLIB
PETSC_TIME_WITH_SYS_TIME
PETSC_HAVE_MATH_H
PETSC_HAVE_ENDIAN_H
PETSC_HAVE_LIMITS_H
PETSC_HAVE_SEARCH_H
PETSC_HAVE_SCHED_H
PETSC_HAVE_PTHREAD_H
PETSC_HAVE_CXX_NAMESPACE
PETSC_HAVE_FORTRAN_TYPE_INITIALIZE
PETSC_HAVE_LIBDL
PETSC_HAVE_LIBQUADMATH
PETSC_HAVE_LIBX11
PETSC_HAVE_LIBZ
PETSC_HAVE_LIBTRIANGLE
PETSC_HAVE_LIBMETIS
PETSC_HAVE_LIBPARMETIS
PETSC_HAVE_LIBHDF5HL_FORTRAN
PETSC_HAVE_LIBHDF5_FORTRAN
PETSC_HAVE_LIBHDF5_HL
PETSC_HAVE_LIBHDF5
PETSC_HAVE_LIBPNETCDF
PETSC_HAVE_LIBNETCDF
PETSC_HAVE_LIBEXODUS
PETSC_HAVE_LIBBLAS
PETSC_HAVE_LIBLAPACK
PETSC_HAVE_LIBSTDC__
PETSC_HAVE_LIBMPI_USEMPIF08
PETSC_HAVE_LIBMPI_USEMPI_IGNORE_TKR
PETSC_HAVE_LIBMPI_MPIFH
PETSC_HAVE_LIBMPI
PETSC_HAVE_LIBGFORTRAN
PETSC_HAVE_LIBGCC_S
PETSC_HAVE_LIBPTHREAD
PETSC_HAVE_LIBSUNDIALS_CVODE
PETSC_HAVE_LIBSUNDIALS_NVECSERIAL
PETSC_HAVE_LIBSUNDIALS_NVECPARALLEL
PETSC_HAVE_LIBML
PETSC_HAVE_LIBSUPERLU_DIST
PETSC_HAVE_LIBUMFPACK
PETSC_HAVE_LIBKLU
PETSC_HAVE_LIBCHOLMOD
PETSC_HAVE_LIBBTF
PETSC_HAVE_LIBCCOLAMD
PETSC_HAVE_LIBCOLAMD
PETSC_HAVE_LIBCAMD
PETSC_HAVE_LIBAMD
PETSC_HAVE_LIBSUITESPARSECONFIG
PETSC_HAVE_LIBSCALAPACK
PETSC_HAVE_LIBCMUMPS
PETSC_HAVE_LIBDMUMPS
PETSC_HAVE_LIBSMUMPS
PETSC_HAVE_LIBZMUMPS
PETSC_HAVE_LIBMUMPS_COMMON
PETSC_HAVE_LIBPORD
PETSC_HAVE_LIBHYPRE
PETSC_USE_SCALAR_REAL
PETSC_HAVE_REAL___FLOAT128
PETSC_RETSIGTYPE
PETSC_SIZEOF_SHORT
PETSC_SIZEOF_MPI_COMM
PETSC_SIZEOF_MPI_FINT
PETSC_HAVE_VPRINTF
PETSC_HAVE_VFPRINTF
PETSC_HAVE_MKSTEMP
PETSC_HAVE_GETHOSTBYNAME
PETSC_HAVE_SOCKET
PETSC_HAVE_TIMES
PETSC_HAVE_SIGSET
PETSC_HAVE_GETTIMEOFDAY
PETSC_HAVE_SIGNAL
PETSC_HAVE_GET_NPROCS
PETSC_HAVE_SIGACTION
PETSC_HAVE__GFORTRAN_IARGC
PETSC_HAVE_SHARED_LIBRARIES
PETSC_USE_GDB_DEBUGGER
PETSC_VERSION_BRANCH_GIT
PETSC_HAVE_MPI_COMM_F2C
PETSC_HAVE_MPI_COMM_C2F
PETSC_HAVE_MPI_FINT
PETSC_HAVE_MPI_REPLACE
PETSC_HAVE_MPI_WIN_ALLOCATE_SHARED
PETSC_HAVE_MPI_WIN_SHARED_QUERY
PETSC_HAVE_MPI_ALLTOALLW
PETSC_HAVE_MPI_COMM_SPAWN
PETSC_HAVE_MPI_TYPE_GET_EXTENT
PETSC_HAVE_PTHREAD_BARRIER_T
PETSC_HAVE_SCHED_CPU_SET_T
PETSC_HAVE_SYS_SYSCTL_H
PETSC_LEVEL1_DCACHE_SIZE
PETSC_LEVEL1_DCACHE_ASSOC
