[petsc-dev] circular dependencies SLEPc
Matthew Knepley
knepley at gmail.com
Wed Jun 26 18:04:35 CDT 2019
On Wed, Jun 26, 2019 at 4:11 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Wed, Jun 26, 2019 at 3:42 PM Jed Brown via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> >> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >> >>> It is still a PC, it may as part of its computation solve an
> >> eigenvalue problem but its use is as a PC, hence does not belong in
> SLEPc.
> >> >> Fine; it does not belong in src/ksp/pc/.
> >> > Why not? From the code mangement point of view that is the perfect
> >> place for it. It just depends on an external package in the same way
> that
> >> PCHYPRE depends on an external library. Having it off in some other
> >> directory src/plugins would serve no purpose. Of course making sure it
> >> doesn't get compiled into -lpetsc may require a tweak to the make
> >> infrastructure. Make could, for example, skip plugin subdirectories for
> >> example.
> >> I think it's confusing to have code that is part of libpetsc.so
> >> alongside code that is not (e.g., won't be accessible to users unless
> >> they also build SLEPc and link the plugin).
> >> > BTW: Matt's perverse use of SNES from DMPLEx could also be fixed to
> >> > work this way instead of the disgusting PetscObject casting used to
> >> > cancel the SNES object.
> >> That code could be part of libpetscsnes.so.
> > What? I thought I moved everything to SNES a long time ago.
> I thought there was a place where SNES was cast to PetscObject. There
> is DMAddField, but it's different.
I can't find it right now. Yeah, AddField is waiting for a true
Discretization object.
I think its spelled G-O-D-O-T.
> PetscViewerVTKAddField is another example of code that uses PetscObject
> to avoid depending on a higher level type like Vec.
Viewer is a weird mixin with everything.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190626/7034bdc3/attachment.html>
