[petsc-dev] circular dependencies SLEPc
    Matthew Knepley
    knepley at gmail.com
    Wed Jun 26 14:49:06 CDT 2019
On Wed, Jun 26, 2019 at 3:42 PM Jed Brown via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >>>  It is still a PC, it may as part of its computation solve an
> eigenvalue problem but its use is as a PC, hence does not belong in SLEPc.
> >> Fine; it does not belong in src/ksp/pc/.
> >   Why not? From the code mangement point of view that is the perfect
> place for it. It just depends on an external package in the same way that
> PCHYPRE depends on an external library. Having it off in some other
> directory src/plugins would serve no purpose. Of course making sure it
> doesn't get compiled into -lpetsc may require a tweak to the make
> infrastructure. Make could, for example, skip plugin subdirectories for
> example.
> I think it's confusing to have code that is part of libpetsc.so
> alongside code that is not (e.g., won't be accessible to users unless
> they also build SLEPc and link the plugin).
> >   BTW: Matt's perverse use of SNES from DMPLEx could also be fixed to
> >   work this way instead of the disgusting PetscObject casting used to
> >   cancel the SNES object.
> That code could be part of libpetscsnes.so.
What? I thought I moved everything to SNES a long time ago.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190626/34407183/attachment.html>
